289
Vertical Scrollbar overlapping last column
 Hey there:
We are having this issue where we are generating columns dynamically for our xamDatagrid and when the grid loads, the vertical scrollbar is overlapping the last column. For some columns we give in a fixed width and some without the fixed width. We did try to avoid the issue by placing an empty column at the last position but that didn't help either.
I came across a similar post stating the same issue in the WebGrid. They worked it around by the framStyle property. But we aren't using any such in our xamDatagrid.
 Any help would be appreciated.
Ferhaad
  • 28407
    HI,
     I was unable to reproduce this with our latest build 11.1.2053.
     Can you attach a small isolated sample that replicates this issue.
     Sincerely,
     Matt
     DSE
