225
DataPoint (really DataContext) on click?
When showing time series data with the time dimension along the x axis, how could i get the corresponding date when the user clicks on the graph?
  • 225
    Verified Answer
    private void theChart_MouseLeftButtonDown(object sender, MouseButtonEventArgs e)
    var chart = (XamDataChart)sender;
    var s = chart.Series.FirstOrDefault();
    if (s == null)
    return;
    var position = e.GetPosition(s);
    var xAxis = theChart.Axes.OfType<CategoryXAxis>().First();
    var yAxis = theChart.Axes.OfType<NumericYAxis>().First();
    var viewport = new Rect(0, 0, xAxis.ActualWidth, yAxis.ActualHeight);
    var window = s.SeriesViewer.WindowRect;
    var scalerParams = new ScalerParams(window, viewport, false);
    var unscaledX = xAxis.GetUnscaledValue(position.X, scalerParams);
    var unscaledY = yAxis.GetUnscaledValue(position.Y, scalerParams);
    var index = (int)Math.Floor(unscaledX);
    var idx = 0;
    var iEnumerable = s.ItemsSource.GetEnumerator();
    var item = default(ChartData);
    while (iEnumerable.MoveNext())
    if (idx == index)
    item = (ChartData)iEnumerable.Current;
    break;
    idx++;
    Console.WriteLine(item.Date);
    public class ChartData
    public DateTime Date { get; set; }
    public double Value1 { get; set; }
    public double Value2 { get; set; }
    public double Value3 { get; set; }
    public static ObservableCollection<ChartData> GenerateData(int count)
    ObservableCollection<ChartData> data = new ObservableCollection<ChartData>();
    Random r = new Random();
    ChartData data0 = new ChartData
    Date = DateTime.Now,
    Value1 = r.Next(20, 40),
    Value2 = r.Next(20, 40),
    Value3 = r.Next(20, 40),
    data.Add(data0);
    for (int i = 1; i < count; i++)
    ChartData dat = new ChartData
    Date = DateTime.Now.AddDays(i),
    if (r.NextDouble() > .5)
    dat.Value1 = data[i - 1].Value1 + r.NextDouble();
    dat.Value2 = data[i - 1].Value2 + r.NextDouble();
    dat.Value3 = data[i - 1].Value3 + r.NextDouble();
    else
    dat.Value1 = data[i - 1].Value1 - r.NextDouble();
    dat.Value2 = data[i - 1].Value2 - r.NextDouble();
    dat.Value3 = data[i - 1].Value3 - r.NextDouble();
    data.Add(dat);
    return data;
