60
How do I enable TwoWay Binding in UseAlternateBinding mode?
I recently upgraded to v14.2 of the XamDataGrid and noticed that the UnboundField class (which I used in all my grids) had been deprecated.  Now I'm trying to refactor my grids to use non-deprecated fields but am having issues getting them to work in a TwoWay binding fashion.
I'm trying to use Numeric/Text/DateTime fields, all of them are in UseAlternateBinding mode as my source collection in the ViewModel uses a generic interface type and Name binding doesn't work.  I'm finding that when I edit a value it only updates the cell, the new value is not pushed back into my source object, how do I make this happen?
I've tried specifying Mode=TwoWay on the binding I supply to the AlternateBinding property but this had no effect.  I had a similar issue a couple of days ago whilst trying to use a converter, it's only when I provide a converter to the Converter property on the field it gets used so it appears that anything other than the Path is ignored by the AlternateBinding property.  However, in this case there is no separate BindingMode property on the field that I can use.
