1735
Multiple selection/edits in xamPropertyGrid
I have two questions regarding selection/editing of multiple objects in the xamPropertyGrid:
1. When a property is edited in multiple selection mode, is there a way (an event?) to tell me when the first effected object's property is updating and the last effected property has been updated? The reason I need this is that I use an undo/redo manager for the edited objects, and I want all edits in a multiple selection edit to be encapsulated in the same undo/redo transaction. I therefore need a way to be able to set up and commit such transactions.
2. In multiple selection mode, is there a way to tell the property grid that a property should not be available for multiple selection edit? Although multiple selection edit works well in most cases, I have object properties that should only be allowed to be edited when no other objects are selected.
Leif
