is it possible to use AutoGenerateColumns="True" and additionaly set a DataTemplate for these autogenerated columns?
Stephan
Thank you for your feedback.
Please let me know if you need any further assistance on the matter.
Thank you for your reply. I tried to solve the problem completely in xaml. But that doesn't seem to work. I'll do it in code behind
Hello ,
Thank you for your post.
I have been looking into it. I have been investigating your requirement and if I understand correctly what you are trying to achieve, that I can suggest is to handle ColumnAutoGenerated event of XamGrid. You can read more details about it from the following link from our online documentation:
http://help.infragistics.com/Help/Doc/WPF/2015.1/CLR4.0/html/xamGrid_Auto_Generate_Columns.html
In the event handler you can get the Column by ColumnAutoGeneratedEventArgs and perform the needed operations to achieve what you want. I created short sample application based on your scenario to show you how you can implement this approach. Please let me know if I am missing something from your scenario. If the sample application doesn’t cover your expectations feel free to modify it with the functionality that you are using, so I can investigate it further for you.
If you require any further assistance, please do not hesitate to ask.
