I've tried with numerous pictures of barcodes to decode and only a couple random ones are working..
In the event BarcodeReader_DecodeComplete they mostly fail because e.SymbolFound = false;
See attachment at the images that are working against the ones that are not working.
Is there anything that can be done about this?
Thanks, Grant
Hi Grant,
I am just checking if you had a chance to look into this and if you would like any further assistance on the matter.
Hello Grant and thank you for posting!
After reviewing the sample screenshots I am not sure that I could say the type of Barcode that is used for a few of the provided ones. It seems that the WORKING and WORKING2 are generated as XamCode39Barcode and they could be easily recognized. I have also tried to generate the NOT_WORKING1 and NOT_WORKING2 from the text and it looks like they are neither XamCode39Barcode nor any of the other barcode symbologies that are supported - http://help.infragistics.com/doc/WPF/2015.1/CLR4.0/?page=xamBarcode_Barcode_Symbologies.html.Would you please let me know what the exact type of those barcodes is? I have also noted that the other five images have a complex background. Please note that this may cause incorrect data to be read so I will suggest you to filter the image prior to running the barcode reader.
