As per our requirement in the xamdatagrid we have an unbound field in which we want to display another xamdatagrid. For achieving this we have added a Control Template (which has a scrollview and a xamgrid within it) and associated it to the xamdatagrid’s Unbound field. The issue is that some time the control template does not render completely and as a result the grid row does not open (please see attached the screen shot). Can you please let us know what could be the possible reason for this issue and is there any workaround that we could implement to resolve this issue.
I am just checking if there is anything else I can do for you.
Hello Rheal,
Thank you for your post.
I have been looking into it. What I can suggest is to compare the Settings for Graphic card between the desktop machines and laptop. I tested the sample application on my side with different desktop machines and laptops and I could not managed to reproduce the behavior that you have described. Could you please send me, an isolated sample project, where this is reproduced, so I can investigate it further for you and I would be able to support you.
Please let me know if you need any further assistance on the matter.
We have made changes to our code by removing the wpf grid control from the control template just as you had given in your sample application. By doing this we are able to resolve the issue on our desktop machines, however one of our laptops still face the rendering issue. Herewith i have attached the config for your reference. Could it be related to the graphic card? Looking forward to hearing from you.
I have been looking into it. I tested the sample application with the latest Service Release of version 10.3 build number 2337 and I could not managed to reproduce the behavior that you have described. Would you please provide me with the build number of assemblies that you are using? Are you using some theme or styles? It seems like I am missing something about your scenario, so if this is still an issue for you, could you please send me, an isolated sample project, where this is reproduced or modify my sample application with the functionality and styles that you are using , so I can investigate it further for you. I attached two screenshots to show you how the sample application works on my side with version 10.3 and 15.1.
