1190
XamDataGrid crash when closing with FieldChooser open
I have a XamDataGrid that is hosted in a XamDockManager floating window.  I found that if i show the FieldChooser on the grid and then close the floating window that the grid is in then the app with crash.  I worked around this by forcibly closing the FieldChooser but I think this is a bug that should be fixed.
  • 34810
    Hello John,
    Thank you for your post!
    I have been investigating this issue that you are referring to, and I have reproduced it. The workaround to this is - as you have said - to force close the FieldChooser on close of the floating pane. I also agree that this is indeed a bug, and so I have asked our engineering teams to examine this issue further. To ensure it receives attention, I have logged it in our internal tracking system with a development ID of 200632.
    I have created a private case for you for this matter so that you can track the progress of this development issue. The case number is CAS-156444-S8G4L3. You can access it here: https://ko.infragistics.com/my-account/support-activity.
    Sincerely,
    Andrew
    Associate Developer
    Infragistics Inc.
    www.infragistics.com/support
