1590
How to style native WPF controls in combination with Infragistics theming
Hi, In our application we are using various native WPF controls that are partly styled. For example, a color image is used for a button, and a gray image is shown when the button is disabled. However, the button background should always be according to the current Infragistics theme (this is what I mean with "partly" styled; partly our own style, partly IG). In order to set the image, a WPF Style is used. However, when changing the Infragistics theme, the IG part of the style is ignored for the image button. If you look at my sample, you will see what I mean. The buttons on the right are initially styled correctly, but they do not follow theme changes. How can I achieve this?
Thanks, Stefan
TestThemingNativeWPFControls.zip
  • 34810
    Verified Answer
    Hello Stefan,
    Thank you for your post!
    I believe the behavior you are seeing with the Style is expected. The reason for this is because you are defining your own Style for button which is based on a Button style. At the start of your application, it appears that the IGTheme theme is applied, and so that style for your button assumes the style specifications for the IGTheme for whichever properties are not set in your new style. This style then remains static, and will not change when changing the overall theme of the application.
    I would recommend that instead of styling the button, you add Content directly to your buttons in your XAML, and style that content instead. This will allow you to have the theme changes effect the button, while still applying your content changes within the button.
    I have attached a modified version of the sample you sent to demonstrate.
    Sincerely,
    Andrew
    Associate Developer
    Infragistics Inc.
    www.infragistics.com/support
