25
Experiencing System.NullReferenceException when TransitionDuration is set to 1500 miliseconds for ScatterLineSeries instance.
Greetings for the day!
My screen displays a X-Y Series based chart using XamDataChart control (Assembly - InfragisticsWPF4.Controls.Charts.XamDataChart.v14.1.dll, v14.1.20141.2027).
As per my functional scenario I want to reload my chart when New & Save operation is performed on my screen. In this reload operation I create ScatterLineSeries instance in code behind and add it to XamDataChart.Series Collection. My screen has buttons respective to New and Save operation. When I try to click my New and Save button in sequence fairly quickly (i.e. keeping minimum possible delay between two operations), I get unhandled exception. Please check the stack strace at end of the post. I observed that this exception is happening due to TransitionDuration value set for ScatterLineSeries instance. Exception happens when this value is set to 1500 milliseconds. If I decrease it to 500 milliseconds then exception disappears.
Please elaborate to me on this XamDataChart-ScatterLineSeries behaviour. When I use 1500 milliseconds, I have to maintain some delay (time gap) between two button clicks (i.e. in between New and Save click), if I do it very quickly then I get this exception. And if I change TransitionDuration value to 500 milliseconds, then exception does not occur even if I click two buttons very quickly.
Stack Trace - System.NullReferenceException: Object reference not set to an instance of an object.
at Infragistics.Controls.Charts.ScatterLineSeries.<.ctor>b__0(OwnedPoint maxPoint, ScatterFrame minFrame, ScatterFrame maxFrame)
at Infragistics.Controls.Charts.ScatterFrameBase`1.InterpolatePoint(OwnedPoint point, Single p, OwnedPoint minPoint, OwnedPoint maxPoint, T minFrame, T maxFrame)
at Infragistics.Controls.Charts.DictInterpolator`3.Interpolate(IDictionary`2 target, Single p, IDictionary`2 min, IDictionary`2 max, TFrame minFrame, TFrame maxFrame)
at Infragistics.Controls.Charts.ScatterFrameBase`1.Interpolate(Single p, Frame minFrame, Frame maxFrame)
at Infragistics.Controls.Charts.ScatterBase.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue)
at Infragistics.Controls.Charts.ScatterLineSeries.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue)
at Infragistics.Controls.Charts.Series.<.ctor>b__4(Object o, PropertyUpdatedEventArgs e)
at Infragistics.Controls.Charts.Series.RaisePropertyChanged(String propertyName, Object oldValue, Object newValue)
at Infragistics.Controls.Charts.Series.<.cctor>b__1e(DependencyObject sender, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
at Infragistics.Controls.Charts.Series.set_TransitionProgress(Double value)
at Infragistics.Controls.Charts.Series.Animator_PropertyChanged(Object sender, PropertyChangedEventArgs e)
at Infragistics.DoubleAnimator.set_TransitionProgress(Double value)
at Infragistics.DoubleAnimator.Tick()
at Infragistics.DoubleAnimator.Update(Boolean flush)
at Infragistics.DoubleAnimator.CompositionTarget_Rendering(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
at System.Windows.Media.MediaContext.AnimatedRenderMessageHandler(Object resizedCompositionTarget)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Application.RunInternal(Window window)
at System.Windows.Application.Run()
at AvocetVM.App.Main() in d:\Avocet\Source\Workspaces\AvocetMain\Trunk\AvocetVM\obj\Debug\App.g.cs:line 0
at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)
at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
at System.Threading.ThreadHelper.ThreadStart()
Thanks & Regards,
Vinayak Nikam
