435
XamNumericInput ErrorTemplate Remains
Hi Infragistics,
We're using the latest 14.2 Service Release and have discovered the following issue.
A Style has been defined to accept a valid range, in this case a year...
<Style x:Key="ValidatedXamNumericInputYear" TargetType="{x:Type ig:XamNumericInput}">
    <Setter Property="Width" Value="60"/>
    <Setter Property="ValueTypeName" Value="Int32"/>
    <Setter Property="SpinButtonDisplayMode" Value="Always"/>
    <Setter Property="PromptChar" Value=""/>
    <Setter Property="NullText" Value="{Binding Source={x:Static sys:DateTime.Today}, Path=Year}"/>
    <Setter Property="InvalidValueBehavior" Value="RevertValue"/>
    <Setter Property="ValueConstraint">
        <Setter.Value>
            <ig:ValueConstraint ValidateAsType="Integer32" MinInclusive="1982" MaxInclusive="2100"/>
        </Setter.Value>
    </Setter>
</Style>
If the contents of the input is then cleared\deleted and a valid number re-entered, the ErrorTemplate remains...
The control XMAL is...
<ig:XamNumericInput Style="{StaticResource ValidatedXamNumericInputYear}" Value="{Binding Path=<ViewModelProperty>, Mode=TwoWay, UpdateSourceTrigger=PropertyChanged, ValidatesOnDataErrors=True, ValidatesOnExceptions=True}"/>
I believe there is also a second issue that is linked.
The documentation states that the Value property will only be updated if the value is valid. In the case of the above entering 1 (for example) still updates the Value property even though it's invalid. This causes issues as the ViewModelProperty is then updated with an incorrect value.
