I am getting an issue where the connections are not getting displayed in the XamNetworkNode.
What I am doing here is
1. Arranging the nodes in row wise (in a zig-zag pattern) in order to eliminate overlaps in auto arrangement.
2. Navigating from one node to other node by clearing the current selected node and making the next/previous linked node as selected.
3. Bringing the node that is selected into view by adjusting the window rectangle.
While navigating in this way the connections are just getting disappeared. I am not getting any exception in this custom logic as well.
I have attached the sample project. And 2 snapshots to describe the problem.
To Reproduce: Run the sample, Click on "ArrangeInRow" button, Manually do panning and/or zoom such that the nodes in a single row are completely visible, Select last node in the first visible row, click on "Previous" button or press "comma-key" from key board. The connections get disappear.
Please help on this problem.
Prasad
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account\My Keys and Downloads.
Thank you for your post.
I have been looking into your question and I answered on your question about the fix you mentioned through the ticket. Please take a look.
Thank to for using Infragistics component.
Thank you for the update.
Let the issue be debugged.
Is there any temporary fix that I can apply for this. I mean a way to re-draw the connection lines by any means of calling methods like Invalidate, RePaint, Refresh etc.?
Thanks & Regardsm
I have been looking into your post. Currently our developers are researching this issue for you. Once they are done with their research you would receive a notification.
Please let me know if you have any further questions on this matter.
Any update on this issue?
