Is it possible to fix connectors at corners/required position of the shape and keep the connection lines always fixed to same connector even while moving the shapes manually?
Something like in attachment.
Prasad
I am just checking if you have any other questions on the fixed connectors.
Hello and thank you for your post!
The connection points that are used are automatically adjusted if they are not specified. If you set the EndNodeConnectionPointName to a value it won’t be adjusted e.g. <ig:ConnectionDefinition.ConnectionStyle> <Style TargetType="ig:DiagramConnection"> <Setter Property="EndNodeConnectionPointName" Value="Right"/> <Setter Property="Stroke" Value="DarkGreen"/> <Setter Property="Foreground" Value="DarkGreen"/> <Setter Property="Fill" Value="DarkGreen"/> <Setter Property="Content" Value="Reports to"/> <Setter Property="EndCapType" Value="None"/> <Setter Property="StartCapType" Value="FilledArrow"/> </Style> </ig:ConnectionDefinition.ConnectionStyle>You may also refer to the following help topic for details on the same: http://help.infragistics.com/Help/Doc/WPF/2015.1/CLR4.0/html/xamDiagram_Configuring_the_Start_and_End_of_Diagram_Connections.html#_Ref388549185
