As per one of the requirement. I need to show data in following format:
Above image is the sample data / layout that I am able to generate. Now there are few columns that will be fixed in data grid. When I set the respective properties, it shows the fixed field splitter as expected. The splitter looks like follow:
If you notice for child records its not showing the field splitter line. That too is expected behavior as the field splitter belongs to Parent and not child. My requirement is to extend the parent field splitter in child data grid. Is there any way to achieve that?
I also tried fixed fields in child fieldlayout. That made the field splitter visible for the child as well. However, when on dragging the parent field splitter, child column is adjusting its width but vice versa is not working.
Thanks in advance for any help.
Hello Dharmesh,
I have been looking into your latest post. What I can suggest is to take a look at the following forum threads where similar issues are discussed: http://ko.infragistics.com/community/forums/t/70268.aspx, http://ko.infragistics.com/community/forums/t/62567.aspx, http://ko.infragistics.com/community/forums/t/93020.aspx.
On these threads you would also find sample applications too. Please do not hesitate to let me know if you have any further questions on this matter.
First of all sorry for late reply.
I am not able to add multiple images and not sure from where I can add those.
Anyways, my problem is something similar to this post:
http://ko.infragistics.com/community/forums/p/59135/407997.aspx
As per the stefen comment, header presenter and datarecordpresenter style need to be set for making header completely in visible, I don't want to introduce datarecordpresenter style just for setting one control visibility property. In short I want to avoid styling any presenter (I am ok with HeaderPresenterStyle).
The post I mentioned is 2/3 yrs old. I am currently using 12.1 version. Is there something new come up in latest version to support or solve my issue?
Any help comment is highly appreciated. Thank you in advance...
Hello Dharmesh ,
Thank you for your post.
I have been looking into it and it seems that for some reason three from your screenshots does not pass correctly throught the forum thread. Would you please re-send your attachments using Internet Explorer or Mozilla Firefox and send them as zip file in order to ensure that the files will be received successfully? I am not sure that I understand correctly your issue, so would you please provide me with more details about it.
I created a sample application based on your scenario and I could not managed to reproduce the behavior that you have described. If you are not able to reproduce the issue with the attached sample application, would you please modify it with the functionality, that you are using, so it reproduces the issue. This way I would be able to further investigate this for you and provide you with more detailed information on this matter.
