Hi all
When I try to bind WPF application with
<ig:ThemeManager.Theme> <ig:Office2013Theme StyleMicrosoftControls="True" /></ig:ThemeManager.Theme>
I've got the exception(look at attached pic). The main xaml looks like
<Window x:Class="Backup.MainWindow" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:ignore="http://www.ignore.com" xmlns:ig="http://schemas.infragistics.com/xaml" mc:Ignorable="d ignore" Height="300" Width="300" Title="Backup V1.0" WindowStartupLocation="CenterScreen" ResizeMode="NoResize" WindowStyle="None" DataContext="{Binding Main, Source={StaticResource Locator}}"> <Window.Resources> </Window.Resources> <ig:ThemeManager.Theme> <ig:Office2013Theme StyleMicrosoftControls="True" /> </ig:ThemeManager.Theme> <Grid x:Name="LayoutRoot"> <Button Content="Terst" Height="30" Width="30"></Button> </Grid></Window>
What am I doing wrong?
THanks
We have shipped out a new service release where the issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Keys and Downloads page.
Hi Greg,
I've create a case on your behalf as well the case ID is - CAS-166542--Q1H5B. I've linked it to the development issue 204389 as requested.
You can view the status of all development issues connected to this case from the "Development Issues" tab, when viewing this case on the "My Support Requests" page of our website.
We're currently looking at it and will make our best to get it fixed in the upcoming December SR.
I get the same exceptions when using ThemeManager. Please create a support case on my behalf so I can receive updates on development issue 204389. Is this scheduled to be fixed in the Dec 11 service release? It is hindering us from using a desired solution with themes in our production application.
Hi Kristopher,
I've create a case on your behalf as well the case ID is - CAS-159626-G4Q4G0. Your case is also linked to the same development issue 204389.
Hi Jean-Pascal Robert-Nicoud,
I've created a support case on your behalf. The case number is - CAS-158445-P4Y5S6.
I have logged this behavior in our internal tracking system with a Development ID 204389. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution. I will leave this case open and update you with this information after the review. You can also continue to send updates to this case at any time.
