1235
Synchronize Field With in Layout. Scrolling causes Size changed event.
Hey Guys,
I am using a XamDataGrid and i am trying to Sync mein Field with, which works perfectly as i want it to.
To Sync my Field With I listen to the Size Change Event from the LabelPresenter
private void EventSetter_OnHandler(object sender, SizeChangedEventArgs e)
var lp = sender as LabelPresenter;
if (lp != null)
if (lp.Parent is VirtualizingDataRecordCellPanel && e.PreviousSize.Width != 0)
var layout = (lp.Parent as VirtualizingDataRecordCellPanel).DataContext as FieldLayout;
foreach (var field in layout.Fields)
if (field.Name.Contains("Result"))
field.Width = new FieldLength(lp.Field.CellWidthResolved);
The Problem is when i scroll the Grid Horizontally the Size Changed event occurs. Actually i understand why this is happening but how can i handle this problem so my Labels wont change their size when scrolling?
Markus
