355
XamComboEditor ..how to bind multiple lists to same control in the program ?
Hi ,
I am really new to WPF infragistics. I have an XamComboEditor that needs to have one out of 4 different lists as its ItemsSource based on a user event . Initially in the constructor of my code behind , I am setting the ItemsSource to one of the 4 lists right after InitializeComponent.
When I run the app , it adds 1,2,3... numbers to my XamComboEditor instead of the List I porvided.
Could you help me do this ? Is there any setting I need to override .
My XAML :
<ig:XamComboEditor ItemsSource="{Binding Attributes}" AllowMultipleSelection="True" CheckBoxVisibility="Visible" Name="XamComboEditor" HorizontalAlignment="Left" Margin="559,241,0,0" VerticalAlignment="Top" Width="171"/>
I should not want to set ItemsSource in XAMl since I will keep changing it based on user selection.
My code behind  constructor:
public MainWindow()
List<string> Attributes =new List<string> // one of the 4 lists
"Name",
"Client",
"Country",
"Field",
"Geomarket",
"Area",
"Formation Types",
"Fluid Types",
"Drive Mechanisms",
"EOR Processes"
InitializeComponent();
XamComboEditor.ItemsSource = Attributes;
On debugging I found that it sets up the item source all right. but later on it gets overriden by numbers , which I couldn't track where it got those from.
Prasaanth
