If I use AppMap for create project, I can't use Xamarin.Forms previewer.
It gives an error "Default constructor not found for type...
Do you have same error ?
if I remove the class on my .xaml file it's ok.
x:Class="AppMapProject2.Views.Login" Title="Login">
If I create projet Cross Platform App (Xamarin,Forms) with UI technology : Xamarin.Forms and Code sharing strategy : PCL I can use previewer.
Francois.
Francois,
Currently, the Infragistics Controls do not render in the Xamarin Forms Previewer. It is a known limitation of the previewer as the previewer does not support Skia Sharp rendering.
You should leave the prism:ViewModelLocator.AutowireViewModel="True" as setting this to false will impact runtime performance.
Thank you for bringing up the issue of no default constructor. I will address this with the Prism team.
I Think I have found,
I chage prism:ViewModelLocator.AutowireViewModel="True" to false
and now I have no more error with Xamarin.Forms Previewer.
xmlns="http://xamarin.com/schemas/2014/forms" xmlns:x="http://schemas.microsoft.com/winfx/2009/xaml" xmlns:prism="clr-namespace:Prism.Mvvm;assembly=Prism.Forms" prism:ViewModelLocator.AutowireViewModel="True" xmlns:local="clr-namespace:AppMapProject2.Views;assembly=AppMapProject2" x:Class="AppMapProject2.Views.Login" Title="Login">
