1230
Erro on Sorting on Nullable :Specified cast is not valid.
I am testing the XamDataGrid and I am getting a Specified cast is not valid. when I try and sort a column by a value when the Value is Declared as Nullable, ie [?]
When I change the value to be not nullable I can then sort on that column, should you not be able to sort on Nullable POCO values? I tested with your xamdatacontrol control in Wpf, and that works just fine.
I get the following stack-trace back:
System.InvalidCastException: Specified cast is not valid.
07-07 09:50:51.131 I/MonoDroid( 6266):   at Infragistics.Controls.DataSource.Implementation.DataSourcePropertiesComparer.CompareValues (System.Object xValue, System.Object yValue, System.Boolean currIsDescending, Infragistics.Core.Controls.DataSource.DataSourceSchemaPropertyType schemaType) [0x00296] in E:\Work\1\1220\src\XPlatform\2017.1\Source\DataVisualization\Shared\DataSource\LocalDataSource.cs:780
07-07 09:50:51.131 I/MonoDroid( 6266):   at Infragistics.Controls.DataSource.Implementation.DataSourcePropertiesComparer.Compare (System.Object x, System.Object y) [0x00048] in E:\Work\1\1220\src\XPlatform\2017.1\Source\DataVisualization\Shared\DataSource\LocalDataSource.cs:629
In detail.
public class SelectEntity2
        public int? ID { get; set; }
        public DateTime? NextDueDate { get; set; }
 protected override void OnAppearing()
            base.OnAppearing();
            if (DataGrid.ItemsSource == null)
                CreateData();
                DataGrid.IsVisible = true;
        private void CreateData()
            var items = new List<SelectEntity2>();
            for (int i = 1; i < 101; i++)
                var days = new Random().Next(100);
                if (IsOdd(days))
                  items.Add(new SelectEntity2 {ID = i, NextDueDate = DateTime.Now.AddDays(days)});
                else
                    items.Add(new SelectEntity2 { ID = i, NextDueDate = DateTime.Now.AddDays(-days) });
            DataGrid.AutoGenerateColumns = true;
            DataGrid.ItemsSource = items;
        public static bool IsOdd(int value)
            return value % 2 != 0;
  • 29105
    Thank you for contacting Infragistics. This issue was previously reported and currently under investigation.
    I have created a support case for you: CAS-185436-P1F3N6 with ID 238027. You could reach your case following the link bellow:
    https://ko.infragistics.com/my-account/support-activity
    I will update you via the mentioned case, so if you have any further questions or comments please update your case.
