well, download the trial version for xamarin today, and when I try to create a new project
(File-> New Project-> infragistics-> Xamarin.Forms) I get the following mistake when I want to create the project:
Error: This template tried to load the component assembly "Xamarin.forms.Templates.VisualStudio".
For more information about this problem and how to enable this template, see the topic of documentation related to the customization of the project template.
Unable to create the Project.
help!
thanks for you help... i was installing vs2017 (no preview) and works well....
but i hav other problem to recognize my physical
with appmap
https://ko.infragistics.com/community/forums/p/111381/522471.aspx#522471
thanks again for you help!
I have confirmed that Microsoft has removed the Xamarin.Forms.Templates.VisualStudio wizard that we use in VS2017. We are working on v2 that will create the new Xamarin.Forms .NET Standard projects using the new SDK style csproj format. I have an Alpha version of v2 ready if you would like to test it out.
thank you... im going to try with VS 2017 no preview, and comment later
Actually, since you are using the Preview version, it is possible Xamarin has updated their template wizard assembly version, which would be incompatible with the version we are referencing. I will have to verify this.
Can you create a project using the default Xamarin project template located in the Cross Platform category?
