15
don't load configurator control
I have xamarin.forms project and When I use control XamCategoryChart and press the Configure XamCategoryChart button, I encounter the following error.
08/11/18 17:09:52: System.IO.FileNotFoundException: Could not load file or assembly 'InfragisticsWPF.Controls.Menus.XamDataTree, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.
File name: 'InfragisticsWPF.Controls.Menus.XamDataTree, PublicKeyToken=7dd5c3163f2cd0cb'
   at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
   at System.Reflection.RuntimeAssembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
   at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
   at System.Reflection.Assembly.Load(AssemblyName assemblyRef)
   at System.Windows.Baml2006.Baml2006SchemaContext.ResolveAssembly(BamlAssembly bamlAssembly)
   at System.Windows.Baml2006.Baml2006SchemaContext.ResolveBamlTypeToType(BamlType bamlType)
   at System.Windows.Baml2006.Baml2006SchemaContext.GetClrType(Int16 typeId)
   at System.Windows.Baml2006.Baml2006Reader.Process_DefAttributeKeyType()
   at System.Windows.Baml2006.Baml2006Reader.ReadKeys()
   at System.Windows.ResourceDictionary.SetDeferrableContent(DeferrableContent deferrableContent)
   at System.Windows.Baml2006.WpfSharedBamlSchemaContext.<>c.<Create_BamlProperty_ResourceDictionary_DeferrableContent>b__297_0(Object target, Object value)
   at System.Windows.Baml2006.WpfKnownMemberInvoker.SetValue(Object instance, Object value)
   at MS.Internal.Xaml.Runtime.ClrObjectRuntime.SetValue(XamlMember member, Object obj, Object value)
   at MS.Internal.Xaml.Runtime.ClrObjectRuntime.SetValue(Object inst, XamlMember property, Object value)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
08/11/18 17:09:52: System.Windows.Markup.XamlParseException: Set property 'System.Windows.ResourceDictionary.DeferrableContent' threw an exception. ---> System.IO.FileNotFoundException: Could not load file or assembly 'InfragisticsWPF.Controls.Menus.XamDataTree, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.
   --- End of inner exception stack trace ---
   at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
   at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
   at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
   at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
   at Infragistics.Configurator.Wpf.CategoryChart.Configurator.CategoryChartConfiguratorView.InitializeComponent()
   at Infragistics.Configurator.Wpf.CategoryChart.Configurator.CategoryChartConfiguratorView..ctor(TargetControlLayoutParent targetControlLayoutParent)
   at Infragistics.Configurator.Wpf.CategoryChart.Configurator.CategoryChartConfigurator.Invoke()
   at Infragistics.Configurator.Engine.ConfiguratorStarter.Run()
  • 715
    Rasool,
    Apologies you had this problem.  Please uninstall and reinstall the Configurators.  We have seen this issue before and are not sure why it occurs.
    Have a nice day,
    Karl Shifflett
