Error when building with unity 8.0.0.1909
Error CS1501 No overload for method 'NavigateAsync' takes 3 arguments TestXamarin We need a new AppMapViewModelBase
I too decided to give another shot to using App Map to set up a project. Thought Might help me cut to the chase on overall navigation, etc. First compile errors "No overload for method 'NavigateAsync' takes 2 arguments" I believe that was the error I got maybe a year ago when I tried App Map? You say correctly that it is Prism changed and now it broke App Map, frankly, that seems a little thin? We are now four months later and no fix. The bottom line is App Map a dead product?
I just recently downloaded Xamarin Controls again and thought again about AppMap. I fired it up and basically had this problem. Since the version, it is using in the templates is like a year old now, is there plans to update the templates and of course the Nuget package it uses or is this a dead tool?
Hello Gary,
Thank you for your post.
I have reproduced the behavior you are seeing, but this issue is not a bug within AppMap – it is due to a change in the NavigateAsync method for the Prism library that AppMap uses.
This issue has already been logged in the GitHub repository for Prism, here: https://github.com/PrismLibrary/Prism/issues/2225. For the time being, if you are using a more recent version of Prism, the best workaround I can recommend at the moment is to use one of the other overloads of NavigateAsync in AppMapViewModelBase.
