75
XamDoughnutChart Object reference not set to an instance of an object when resizing
I have a Xam Doughnut Chart that after reloading data after a few times, causes the application to crash. I've been trying to debug for quite some time but i haven't found the issue until i looked into the call stack that showed where it might be blowing up, but I dont know whats causing it.
Code
                                <ig:XamDoughnutChart x:Name="CurrentAccountChart"
                                    Grid.Column="0"
                                    InnerExtent="70">
                                    <ig:XamDoughnutChart.Series>
                                        <ig:RingSeries x:Name="CurrentAccountRingSeries"
                                            FormatLabel="CurrentAccountRingSeries_FormatLabel"
                                            ItemsSource="{Binding CurrentAccountBySeniority}"
                                            LabelExtent="15"
                                            LabelMemberPath="ValueLabel"
                                            LabelInnerColor="#51667a"
                                            LabelOuterColor="#51667a"
                                            LabelsPosition="OutsideEnd"
                                            LeaderLineType="Straight"
                                            LeaderLineVisibility="Visible"
                                            Legend="{x:Reference CurrentAccountLegend}"
                                            LegendLabelMemberPath="Label"
                                            RadiusFactor="0.6"
                                            StartAngle="150"
                                            ValueMemberPath="ValueLabel" />
                                    </ig:XamDoughnutChart.Series>
                                </ig:XamDoughnutChart>
                                <ig:ItemLegend x:Name="CurrentAccountLegend"
                                    Grid.Column="1"
                                    HorizontalOptions="EndAndExpand"
                                    VerticalOptions="EndAndExpand" />
Call Stack with Exception
