Hello everyone,
I wasn't sure where to put these question, so I hope I found the right place for it since it concerns two products. We are currently working with Infragistics WindowsForms and will switch to Infragistics WPF soon. We are working with the Beta 1 of Visual Studio 2010 to create Coded UI Tests for our application.
I am experiencing some difficulties with ComboBoxes and Tables and was wondering if there will be a plugin provided to assure full support of the Infragistics Controls within Visual Studio 2010 and especially with the Coded UI Tests.
Best regards and thanks in advance for the help.
Sebastian Schniedermeyer
Has there been any further development on this effort? Is there a recommended plug in to download? Thanks.
I am interested in more informatio on this, I will send you an email. Thanks
Hi All,
If you are trying to test our Windows Forms controls under coded UI Test, can you shoot me an email to discuss it further.
murtazaa@infragistics.com
Taz.
Hello experts
We are also trying to automate our application with Beta 2 of Visual Studio 2010. Unfortunaltly we are stuck with the Infagistics UltraGrid control. We use WinForm 8.3 controls. A simple test to get the count of rows in a table fails. The debugger cannot evaluate these values (timeout, red icon). With the MS Grid there is no problem.
Is it possible, that Microsoft MSAA technology does not work corectly with Infragistics 8.3? Is there a chance that version 9.2 works with MS Coded UI Tests?
Best regards
Pijus Chanda
Hi Andrew,
we're also having a look at Coded UI Test in Visual Studio 2010 beta 2 to test our WinForms application. Unfortunately, our tests broke on first page, the login form, as the user selects an item from a readonly Infragistics combo.
What I would like to know is: do Infragistics controls already implement Microsoft UI Automation model, or are your team still trying to implement it? In our application we also have custom controls that doesn't come from Infragistics: they're built by our internal team. Do we have to modify our controls, to fully support Coded UI Test?
Thank you, bye! Valentina
