I have been using the following licensed versions of Infragistics:
>> NetAdvantage for .NET 2007 Volume 1 CLR 1.x>> NetAdvantage for .NET 2007 Volume 1 CLR 2.0>> NetAdvantage for .NET 2008 Vol. 3 CLR 2.0>> NetAdvantage for WPF 2008 Vol. 1
I was recently given a machine for development which had a Trial Version of NetAdvantage Ultimate 2010 Vol 3. I uninstalled this trial version, and installed the licensed versions with valid keys.
But for some reason, I cannot drag and drop Infragistics control or create builds (msi) for the application as it says the Trial version of Infragistics has expired.
I tried uninstalling all versions again, deleted anything related to Infragistics from the GAC and reinstalled but get the same error.
Is there any way I can remove traces of the Expired Trial Version? Any help will be greatly appreciated.
Thanks.
P.S. my colleague who did not have Infragistics on his machine was able to install the same licensed versions and create controls and builds without any errors.
More than just the key is needed so if you enter your key you will likely still have issues. The installer for NetAdvantage 2006 Volume 2 is before Windows Vista/7 and UAC. The following knowledge base article may help you to install the earlier version of NetAdvantage:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=9983
If that doesn't help, posting a log file may help us to look into the issue. The following article has details on creating a log file:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=10039
Let me know if you have any questions with this matter.
I've got a question, if I've JUST installed the fine Infragistics product to my Dev machine (windows 7 - the version IS a little old, specifically, NetAdvantage 20062_CLR2x_NET) I'm looking at the Infragistics.License 'key?' under HKEY_Classes_Root in the system registry, and the Data column says '(value not set)'
Can I just enter my Ig registration # here? If the MF-installer didn't load this during installation, as one would Hope and Expect would be the case, do you have a BACKUP method you could impart to us poor, stupid users, please?
Hello TonyGraziano,
I have been looking into your post, and in such case you should first clear the Infragistics content of the licenses.licx file, clean and rebuild your application. After that make sure that the assemblies in your application have their "Specific Version" property set to False, and if the behavior still remains the same than something in the registry of the machine might get corrupted for some reason.
You could verify if the product is registered correctly by looking into a similar location in you registry like:
HKEY_CLASSES_ROOT\Infragistics\NetAdvantage\Net\Self\WPF\CLR3x\Version10.3\SerialNumberIf you have any other questions with this matter please feel free to let us know.
