Hi Team,
I am using Ignite UI for Angular in angular 7 application. I have implemented remote pagination, sorting and filtering. But while exporting excel it exports only first 10 records which ever i am showing in grid initially. I have to export all datas from remote. Can you please provide me sample to implement remote export option in igx-tree-grid.
Looking for your reply thanks.
Hello Prabakaran,
The export service is not part of the igx-tree-grid, you can use it without having a grid at all.
The following link contains description, live sample and source code demonstrating how to export data using the IgniteUI's Excel export service:https://ko.infragistics.com/products/ignite-ui-angular/angular/components/exporter_excel.html
If you require any further assistance on the matter, please let me know.
thanks for your reply @Radko. Actually i can't able to find any examples how to pass customized list of data to export service in grid. can you give me some example how to pass whole remote data to export service. thanks
Is it possible to provide a sample showing your implementation of the remote pagination so that we may help you better ?
Also in general:The exporting service exports the data supplied to it or the data available to the igx-tree-grid (depending on which method of the exporting service you are invoking). If the exporting service is not exporting the entire data source this means that you are not providing the whole data to the service or the igx-tree-grid does not have the entire data source available.
In order to export all data from remote you have to obtain all data from the remote and supply it to the exporting service.
Let me know if I may be of any further assistance.
