8920
creating new project
Hello : I 've run the following command to create new project
ng new  RepoPack01  --collection="@igniteui/angular-schematics" --template=side-nav
got this .. why ?
- Installing packages (npm)...npm ERR! code ERESOLVE
npm ERR! ERESOLVE could not resolve
npm ERR!
npm ERR! While resolving: repo-pack01@0.0.0
npm ERR! Found: @angular/compiler@17.0.9
npm ERR! node_modules/@angular/compiler
npm ERR! @angular/compiler@"^17.0.0" from the root project
npm ERR! peer @angular/compiler@"17.0.9" from @angular/compiler-cli@17.0.9
npm ERR! node_modules/@angular/compiler-cli
npm ERR! dev @angular/compiler-cli@"~17.0.0" from the root project
npm ERR! peer @angular/compiler-cli@"^17.0.0" from @angular-devkit/build-angular@17.0.10
npm ERR! node_modules/@angular-devkit/build-angular
npm ERR! dev @angular-devkit/build-angular@"~17.0.0" from the root project
npm ERR!
npm ERR! Could not resolve dependency:
npm ERR! @angular/platform-browser-dynamic@"^17.0.0" from the root project
npm ERR!
npm ERR! Conflicting peer dependency: @angular/compiler@17.1.1
npm ERR! peer @angular/compiler@"17.1.1" from @angular/platform-browser-dynamic@17.1.1
npm ERR! node_modules/@angular/platform-browser-dynamic
npm ERR!
npm ERR! Fix the upstream dependency conflict, or retry
npm ERR! this command with --force or --legacy-peer-deps
npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
npm ERR!
npm ERR!
npm ERR! For a full report see:
npm ERR! C:\Users\gkheysin\AppData\Local\npm-cache\_logs\2024-01-27T03_00_07_402Z-eresolve-report.txt
npm ERR! A complete log of this run can be found in: C:\Users\gkheysin\AppData\Local\npm-cache\_logs\2024-01-27T03_00_07_402Z-debug-0.log
× Package install failed, see above.
The Schematic workflow failed. See above.
also when applying this steps :
npm config set @infragistics:registry packages.infragistics.com/.../
npm config set //packages.infragistics.com/npm/js-licensed/:username=YOUR_USERNAME
npm config set //packages.infragistics.com/npm/js-licensed/:email=YOUR_IG_EMAIL
npm config set //packages.infragistics.com/npm/js-licensed/:_auth=YOUR_IG_AUTH_TOKEN
Is the YOUR_USERNAME is user name on the account or the one shown on the access token page for npm feed.. e-mail I assume from the account..
Also is that the  problem that I install both Angular Schematics & Ignite UI CLI .. ? If it is how to uninstall them ?
Thanks.
  • 1700
    Verified Answer
    Offline posted in reply to Michael Seidel
  • 1700
  • 8920
    2024-01-29T18_15_52_374Z-debug-0.log
    0 verbose cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
    1 info using npm@10.2.3
    2 info using node@v20.10.0
    3 timing npm:load:whichnode Completed in 2ms
    4 timing config:load:defaults Completed in 3ms
    5 timing config:load:file:C:\Program Files\nodejs\node_modules\npm\npmrc Completed in 2ms
    6 timing config:load:builtin Completed in 3ms
    7 timing config:load:cli Completed in 1ms
    8 timing config:load:env Completed in 1ms
    9 timing config:load:file:C:\_ngIG\RepoPack01\.npmrc Completed in 1ms
    10 timing config:load:project Completed in 2ms
    11 timing config:load:file:C:\Users\gkheysin\.npmrc Completed in 1ms
    12 timing config:load:user Completed in 1ms
    13 timing config:load:file:C:\Users\gkheysin\AppData\Roaming\npm\etc\npmrc Completed in 1ms
    14 timing config:load:global Completed in 1ms
    15 timing config:load:setEnvs Completed in 1ms
    16 timing config:load Completed in 13ms
    17 timing npm:load:configload Completed in 13ms
    18 timing config:load:flatten Completed in 1ms
    19 timing npm:load:mkdirpcache Completed in 1ms
    20 timing npm:load:mkdirplogs Completed in 1ms
    21 verbose title npm install
    22 verbose argv "install" "--ignore-scripts"
    23 timing npm:load:setTitle Completed in 0ms
    24 timing npm:load:display Completed in 1ms
    25 verbose logfile logs-max:10 dir:C:\Users\gkheysin\AppData\Local\npm-cache\_logs\2024-01-29T18_15_52_374Z-
    26 verbose logfile C:\Users\gkheysin\AppData\Local\npm-cache\_logs\2024-01-29T18_15_52_374Z-debug-0.log
    27 timing npm:load:logFile Completed in 17ms
    28 timing npm:load:timers Completed in 0ms
    29 timing npm:load:configScope Completed in 0ms
    30 timing npm:load Completed in 72ms
    31 timing arborist:ctor Completed in 1ms
    32 silly logfile start cleaning logs, removing 1 files
    33 silly logfile done cleaning log files
    34 timing arborist:ctor Completed in 0ms
    35 timing idealTree:init Completed in 14ms
    36 timing idealTree:userRequests Completed in 0ms
    37 silly idealTree buildDeps
    38 silly fetch manifest @angular/animations@^17.0.0
    39 http fetch GET 200 https://registry.npmjs.org/@angular%2fanimations 36ms (cache hit)
    40 silly fetch manifest @angular/core@^17.0.0
    41 http fetch GET 200 https://registry.npmjs.org/@angular%2fcore 32ms (cache hit)
    42 silly fetch manifest rxjs@~7.8.0
    43 http fetch GET 200 https://registry.npmjs.org/rxjs 29ms (cache hit)
    44 silly fetch manifest zone.js@~0.14.2
    45 http fetch GET 200 https://registry.npmjs.org/zone.js 24ms (cache hit)
    46 silly fetch manifest @angular/common@^17.0.0
    47 http fetch GET 200 https://registry.npmjs.org/@angular%2fcommon 29ms (cache hit)
    48 silly fetch manifest @angular/compiler@^17.0.0
    49 http fetch GET 200 https://registry.npmjs.org/@angular%2fcompiler 32ms (cache hit)
    50 silly fetch manifest @angular/forms@^17.0.0
    51 http fetch GET 200 https://registry.npmjs.org/@angular%2fforms 33ms (cache hit)
    52 silly fetch manifest @angular/platform-browser@^17.0.0
    53 http fetch GET 200 https://registry.npmjs.org/@angular%2fplatform-browser 31ms (cache hit)
    54 silly fetch manifest @angular/platform-browser-dynamic@^17.0.0
    55 http fetch GET 200 https://registry.npmjs.org/@angular%2fplatform-browser-dynamic 32ms (cache hit)
    56 silly fetch manifest @angular/router@^17.0.0
    57 http fetch GET 200 https://registry.npmjs.org/@angular%2frouter 31ms (cache hit)
    58 silly fetch manifest hammerjs@^2.0.8
    59 http fetch GET 200 https://registry.npmjs.org/hammerjs 460ms (cache revalidated)
    60 silly fetch manifest igniteui-angular@~17.0.0
    61 http fetch GET 200 https://registry.npmjs.org/igniteui-angular 396ms (cache revalidated)
    62 silly fetch manifest minireset.css@~0.0.7
    63 http fetch GET 200 https://registry.npmjs.org/minireset.css 387ms (cache revalidated)
    64 silly fetch manifest tslib@^2.3.0
    65 http fetch GET 200 https://registry.npmjs.org/tslib 24ms (cache hit)
    66 silly fetch manifest @angular-devkit/build-angular@~17.0.0
    67 http fetch GET 200 https://registry.npmjs.org/@angular-devkit%2fbuild-angular 25ms (cache hit)
    68 silly fetch manifest @angular/compiler-cli@~17.0.0
    69 http fetch GET 200 https://registry.npmjs.org/@angular%2fcompiler-cli 29ms (cache hit)
    70 silly fetch manifest @angular/compiler@17.0.9
    71 silly fetch manifest @angular/core@17.0.9
    72 silly fetch manifest typescript@~5.2.2
    73 http fetch GET 200 https://registry.npmjs.org/typescript 40ms (cache hit)
    74 silly fetch manifest @angular/localize@^17.0.0
    75 http fetch GET 200 https://registry.npmjs.org/@angular%2flocalize 33ms (cache hit)
    76 silly fetch manifest @angular/compiler@17.1.1
    77 silly fetch manifest @angular/core@17.1.1
    78 silly fetch manifest rxjs@^6.5.3 || ^7.4.0
    79 silly fetch manifest zone.js@~0.14.0
    80 silly fetch manifest @angular/compiler-cli@17.1.1
    81 silly fetch manifest typescript@>=5.2 <5.4
    82 silly fetch manifest @angular/platform-server@^17.0.0
    83 http fetch GET 200 https://registry.npmjs.org/@angular%2fplatform-server 28ms (cache hit)
    84 silly fetch manifest @angular/service-worker@^17.0.0
    85 http fetch GET 200 https://registry.npmjs.org/@angular%2fservice-worker 29ms (cache hit)
    86 silly fetch manifest jest@^29.5.0
    87 http fetch GET 200 https://registry.npmjs.org/jest 29ms (cache hit)
    88 silly fetch manifest node-notifier@^8.0.1 || ^9.0.0 || ^10.0.0
    89 http fetch GET 200 https://registry.npmjs.org/node-notifier 24ms (cache hit)
    90 silly fetch manifest jest-environment-jsdom@^29.5.0
    91 http fetch GET 200 https://registry.npmjs.org/jest-environment-jsdom 26ms (cache hit)
    92 silly fetch manifest canvas@^2.5.0
    93 http fetch GET 200 https://registry.npmjs.org/canvas 26ms (cache hit)
    94 silly fetch manifest karma@~6.4.0
    95 http fetch GET 200 https://registry.npmjs.org/karma 26ms (cache hit)
    96 silly fetch manifest ng-packagr@^17.0.0
    97 http fetch GET 200 https://registry.npmjs.org/ng-packagr 28ms (cache hit)
    98 silly fetch manifest tailwindcss@^2.0.0 || ^3.0.0
    99 http fetch GET 200 https://registry.npmjs.org/tailwindcss 29ms (cache hit)
    100 silly fetch manifest protractor@^7.0.0
    101 http fetch GET 200 https://registry.npmjs.org/protractor 34ms (cache hit)
    102 silly fetch manifest @angular-eslint/builder@^17.0.0
    103 http fetch GET 200 https://registry.npmjs.org/@angular-eslint%2fbuilder 101ms (cache revalidated)
    104 silly fetch manifest eslint@^8.52.0
    105 http fetch GET 200 https://registry.npmjs.org/eslint 66ms (cache revalidated)
    106 silly fetch manifest @angular-eslint/eslint-plugin@^17.0.0
    107 http fetch GET 200 https://registry.npmjs.org/@angular-eslint%2feslint-plugin 100ms (cache revalidated)
    108 silly fetch manifest @angular-eslint/eslint-plugin-template@^17.0.0
    109 http fetch GET 200 https://registry.npmjs.org/@angular-eslint%2feslint-plugin-template 99ms (cache revalidated)
    110 silly fetch manifest @angular-eslint/schematics@^17.0.0
    111 http fetch GET 200 https://registry.npmjs.org/@angular-eslint%2fschematics 159ms (cache revalidated)
    112 silly fetch manifest @angular/cli@~17.0.0
    113 http fetch GET 200 https://registry.npmjs.org/@angular%2fcli 28ms (cache hit)
    114 silly fetch manifest @angular-eslint/template-parser@^17.0.0
    115 http fetch GET 200 https://registry.npmjs.org/@angular-eslint%2ftemplate-parser 169ms (cache revalidated)
    116 silly fetch manifest @types/jasmine@~5.1.1
    117 http fetch GET 200 https://registry.npmjs.org/@types%2fjasmine 35ms (cache hit)
    118 silly fetch manifest @typescript-eslint/eslint-plugin@6.9.1
    119 http fetch GET 200 https://registry.npmjs.org/@typescript-eslint%2feslint-plugin 265ms (cache updated)
    120 silly fetch manifest @typescript-eslint/parser@6.9.1
    121 http fetch GET 200 https://registry.npmjs.org/@typescript-eslint%2fparser 229ms (cache updated)
    122 silly fetch manifest @igniteui/angular-schematics@~17.1.1314
    123 http fetch GET 200 https://registry.npmjs.org/@igniteui%2fangular-schematics 791ms (cache revalidated)
    124 silly fetch manifest jasmine-core@~5.1.0
    125 http fetch GET 200 https://registry.npmjs.org/jasmine-core 26ms (cache hit)
    126 silly fetch manifest karma-chrome-launcher@~3.2.0
    127 http fetch GET 200 https://registry.npmjs.org/karma-chrome-launcher 22ms (cache hit)
    128 silly fetch manifest karma-coverage@~2.2.0
    129 http fetch GET 200 https://registry.npmjs.org/karma-coverage 24ms (cache hit)
    130 silly fetch manifest karma-jasmine@~5.1.0
    131 http fetch GET 200 https://registry.npmjs.org/karma-jasmine 23ms (cache hit)
    132 silly fetch manifest karma-jasmine-html-reporter@~2.1.0
    133 http fetch GET 200 https://registry.npmjs.org/karma-jasmine-html-reporter 25ms (cache hit)
    134 silly placeDep ROOT @angular-devkit/build-angular@17.0.10 OK for: repo-pack01@0.0.0 want: ~17.0.0
    135 silly placeDep ROOT @angular/compiler-cli@17.0.9 OK for: @angular-devkit/build-angular@17.0.10 want: ^17.0.0
    136 silly placeDep ROOT @angular/compiler@17.0.9 OK for: @angular/compiler-cli@17.0.9 want: 17.0.9
    137 silly placeDep ROOT typescript@5.2.2 OK for: @angular/compiler-cli@17.0.9 want: >=5.2 <5.3
    138 silly fetch manifest @ampproject/remapping@2.2.1
    139 silly fetch manifest @angular-devkit/architect@0.1700.10
    140 silly fetch manifest @angular-devkit/build-webpack@0.1700.10
    141 silly fetch manifest @angular-devkit/core@17.0.10
    142 silly fetch manifest @babel/core@7.23.2
    143 silly fetch manifest @babel/generator@7.23.0
    144 silly fetch manifest @babel/helper-annotate-as-pure@7.22.5
    145 silly fetch manifest @babel/helper-split-export-declaration@7.22.6
    146 silly fetch manifest @babel/plugin-transform-async-generator-functions@7.23.2
    147 silly fetch manifest @babel/plugin-transform-async-to-generator@7.22.5
    148 silly fetch manifest @babel/plugin-transform-runtime@7.23.2
    149 silly fetch manifest @babel/preset-env@7.23.2
    150 silly fetch manifest @babel/runtime@7.23.2
    151 silly fetch manifest @discoveryjs/json-ext@0.5.7
    152 silly fetch manifest @ngtools/webpack@17.0.10
    153 silly fetch manifest @vitejs/plugin-basic-ssl@1.0.1
    154 silly fetch manifest ansi-colors@4.1.3
    155 silly fetch manifest autoprefixer@10.4.16
    156 silly fetch manifest babel-loader@9.1.3
    157 silly fetch manifest babel-plugin-istanbul@6.1.1
    158 silly fetch manifest browserslist@^4.21.5
    159 silly fetch manifest browser-sync@2.29.3
    160 silly fetch manifest chokidar@3.5.3
    161 silly fetch manifest copy-webpack-plugin@11.0.0
    162 silly fetch manifest critters@0.0.20
    163 silly fetch manifest css-loader@6.8.1
    164 silly fetch manifest esbuild-wasm@0.19.5
    165 silly fetch manifest fast-glob@3.3.1
    166 silly fetch manifest https-proxy-agent@7.0.2
    167 silly fetch manifest http-proxy-middleware@2.0.6
    168 silly fetch manifest inquirer@9.2.11
    169 silly fetch manifest jsonc-parser@3.2.0
    170 silly fetch manifest karma-source-map-support@1.4.0
    171 silly fetch manifest less@4.2.0
    172 silly fetch manifest less-loader@11.1.0
    173 silly fetch manifest license-webpack-plugin@4.0.2
    174 silly fetch manifest loader-utils@3.2.1
    175 silly fetch manifest magic-string@0.30.5
    176 silly fetch manifest mini-css-extract-plugin@2.7.6
    177 silly fetch manifest mrmime@1.0.1
    178 silly fetch manifest open@8.4.2
    179 silly fetch manifest ora@5.4.1
    180 silly fetch manifest parse5-html-rewriting-stream@7.0.0
    181 silly fetch manifest picomatch@3.0.1
    182 silly fetch manifest piscina@4.1.0
    183 silly fetch manifest postcss@8.4.31
    184 silly fetch manifest postcss-loader@7.3.3
    185 silly fetch manifest resolve-url-loader@5.0.0
    186 silly fetch manifest rxjs@7.8.1
    187 silly fetch manifest sass@1.69.5
    188 silly fetch manifest sass-loader@13.3.2
    189 silly fetch manifest semver@7.5.4
    190 silly fetch manifest source-map-loader@4.0.1
    191 silly fetch manifest source-map-support@0.5.21
    192 silly fetch manifest terser@5.24.0
    193 silly fetch manifest text-table@0.2.0
    194 silly fetch manifest tree-kill@1.2.2
    195 silly fetch manifest tslib@2.6.2
    196 silly fetch manifest undici@5.27.2
    197 silly fetch manifest vite@4.5.1
    198 silly fetch manifest webpack@5.89.0
    199 silly fetch manifest webpack-dev-middleware@6.1.1
    200 silly fetch manifest webpack-dev-server@4.15.1
    201 silly fetch manifest webpack-merge@5.10.0
    202 silly fetch manifest webpack-subresource-integrity@5.1.0
    203 silly fetch manifest esbuild@0.19.5
    204 silly fetch manifest @jridgewell/sourcemap-codec@^1.4.14
    205 silly fetch manifest reflect-metadata@^0.1.2
    206 silly fetch manifest chokidar@^3.0.0
    207 silly fetch manifest convert-source-map@^1.5.1
    208 silly fetch manifest semver@^7.0.0
    209 silly fetch manifest yargs@^17.2.1
    210 silly placeDep ROOT @angular-eslint/builder@17.2.1 OK for: repo-pack01@0.0.0 want: ^17.0.0
    211 silly placeDep ROOT eslint@8.56.0 OK for: @angular-eslint/builder@17.2.1 want: ^7.20.0 || ^8.0.0
    212 silly fetch manifest @nx/devkit@17.2.8
    213 silly fetch manifest nx@17.2.8
    214 silly fetch manifest @eslint-community/eslint-utils@^4.2.0
    215 silly fetch manifest @eslint-community/regexpp@^4.6.1
    216 silly fetch manifest @eslint/eslintrc@^2.1.4
    217 silly fetch manifest @eslint/js@8.56.0
    218 silly fetch manifest @humanwhocodes/config-array@^0.11.13
    219 silly fetch manifest @humanwhocodes/module-importer@^1.0.1
    220 silly fetch manifest @nodelib/fs.walk@^1.2.8
    221 silly fetch manifest @ungap/structured-clone@^1.2.0
    222 silly fetch manifest ajv@^6.12.4
    223 silly fetch manifest chalk@^4.0.0
    224 silly fetch manifest cross-spawn@^7.0.2
    225 silly fetch manifest debug@^4.3.2
    226 silly fetch manifest doctrine@^3.0.0
    227 silly fetch manifest escape-string-regexp@^4.0.0
    228 silly fetch manifest eslint-scope@^7.2.2
    229 silly fetch manifest eslint-visitor-keys@^3.4.3
    230 silly fetch manifest espree@^9.6.1
    231 silly fetch manifest esquery@^1.4.2
    232 silly fetch manifest esutils@^2.0.2
    233 silly fetch manifest fast-deep-equal@^3.1.3
    234 silly fetch manifest file-entry-cache@^6.0.1
    235 silly fetch manifest find-up@^5.0.0
    236 silly fetch manifest glob-parent@^6.0.2
    237 silly fetch manifest globals@^13.19.0
    238 silly fetch manifest graphemer@^1.4.0
    239 silly fetch manifest ignore@^5.2.0
    240 silly fetch manifest imurmurhash@^0.1.4
    241 silly fetch manifest is-glob@^4.0.0
    242 silly fetch manifest is-path-inside@^3.0.3
    243 silly fetch manifest js-yaml@^4.1.0
    244 silly fetch manifest json-stable-stringify-without-jsonify@^1.0.1
    245 silly fetch manifest levn@^0.4.1
    246 silly fetch manifest lodash.merge@^4.6.2
    247 silly fetch manifest minimatch@^3.1.2
    248 silly fetch manifest natural-compare@^1.4.0
    249 silly fetch manifest optionator@^0.9.3
    250 silly fetch manifest strip-ansi@^6.0.1
    251 silly fetch manifest text-table@^0.2.0
    252 silly placeDep ROOT @angular-eslint/eslint-plugin@17.2.1 OK for: repo-pack01@0.0.0 want: ^17.0.0
    253 silly fetch manifest @angular-eslint/utils@17.2.1
    254 silly fetch manifest @typescript-eslint/utils@6.19.0
    255 silly placeDep ROOT @angular-eslint/eslint-plugin-template@17.2.1 OK for: repo-pack01@0.0.0 want: ^17.0.0
    256 silly fetch manifest @angular-eslint/bundled-angular-compiler@17.2.1
    257 silly fetch manifest @typescript-eslint/type-utils@6.19.0
    258 silly fetch manifest aria-query@5.3.0
    259 silly fetch manifest axobject-query@4.0.0
    260 silly placeDep ROOT @angular-eslint/schematics@17.2.1 OK for: repo-pack01@0.0.0 want: ^17.0.0
    261 silly placeDep ROOT @angular/cli@17.0.10 OK for: @angular-eslint/schematics@17.2.1 want: >= 17.0.0 < 18.0.0
    262 silly fetch manifest ignore@5.3.0
    263 silly fetch manifest strip-json-comments@3.1.1
    264 silly fetch manifest tmp@0.2.1
    265 silly fetch manifest @angular-devkit/schematics@17.0.10
    266 silly fetch manifest @schematics/angular@17.0.10
    267 silly fetch manifest @yarnpkg/lockfile@1.1.0
    268 silly fetch manifest ini@4.1.1
    269 silly fetch manifest npm-package-arg@11.0.1
    270 silly fetch manifest npm-pick-manifest@9.0.0
    271 silly fetch manifest pacote@17.0.4
    272 silly fetch manifest resolve@1.22.8
    273 silly fetch manifest symbol-observable@4.0.0
    274 silly fetch manifest yargs@17.7.2
    275 silly placeDep ROOT @angular-eslint/template-parser@17.2.1 OK for: repo-pack01@0.0.0 want: ^17.0.0
    276 silly fetch manifest eslint-scope@^8.0.0
    277 silly placeDep ROOT @angular/animations@17.1.1 OK for: repo-pack01@0.0.0 want: ^17.0.0
    278 silly placeDep ROOT @angular/core@17.1.1 OK for: @angular/animations@17.1.1 want: 17.1.1
    279 silly placeDep ROOT rxjs@7.8.1 OK for: @angular/core@17.1.1 want: ^6.5.3 || ^7.4.0
    280 silly placeDep ROOT zone.js@0.14.3 OK for: @angular/core@17.1.1 want: ~0.14.0
    281 silly fetch manifest tslib@^2.1.0
    282 silly placeDep ROOT @angular/common@17.1.1 OK for: repo-pack01@0.0.0 want: ^17.0.0
    283 silly placeDep ROOT @angular/forms@17.1.1 OK for: repo-pack01@0.0.0 want: ^17.0.0
    284 silly placeDep ROOT @angular/platform-browser@17.1.1 OK for: @angular/forms@17.1.1 want: 17.1.1
    285 timing idealTree Completed in 4613ms
    286 timing command:install Completed in 4618ms
    287 verbose stack Error: could not resolve
    287 verbose stack     at PlaceDep.failPeerConflict (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\arborist\lib\place-dep.js:503:25)
    287 verbose stack     at new PlaceDep (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\arborist\lib\place-dep.js:157:21)
    287 verbose stack     at #buildDepStep (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:933:18)
    287 verbose stack     at async Arborist.buildIdealTree (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\build-ideal-tree.js:196:7)
    287 verbose stack     at async Promise.all (index 1)
    287 verbose stack     at async Arborist.reify (C:\Program Files\nodejs\node_modules\npm\node_modules\@npmcli\arborist\lib\arborist\reify.js:159:5)
    287 verbose stack     at async Install.exec (C:\Program Files\nodejs\node_modules\npm\lib\commands\install.js:152:5)
    287 verbose stack     at async module.exports (C:\Program Files\nodejs\node_modules\npm\lib\cli-entry.js:61:5)
    288 verbose cwd C:\_ngIG\RepoPack01
    289 verbose Windows_NT 10.0.19045
    290 verbose node v20.10.0
    291 verbose npm  v10.2.3
    292 error code ERESOLVE
    293 error ERESOLVE could not resolve
    294 error
    295 error While resolving: repo-pack01@0.0.0
    295 error Found: @angular/compiler@17.0.9
    295 error node_modules/@angular/compiler
    295 error   @angular/compiler@"^17.0.0" from the root project
    295 error   peer @angular/compiler@"17.0.9" from @angular/compiler-cli@17.0.9
    295 error   node_modules/@angular/compiler-cli
    295 error     dev @angular/compiler-cli@"~17.0.0" from the root project
    295 error     peer @angular/compiler-cli@"^17.0.0" from @angular-devkit/build-angular@17.0.10
    295 error     node_modules/@angular-devkit/build-angular
    295 error       dev @angular-devkit/build-angular@"~17.0.0" from the root project
    295 error
    295 error Could not resolve dependency:
    295 error @angular/platform-browser-dynamic@"^17.0.0" from the root project
    295 error
    295 error Conflicting peer dependency: @angular/compiler@17.1.1
    295 error   peer @angular/compiler@"17.1.1" from @angular/platform-browser-dynamic@17.1.1
    295 error   node_modules/@angular/platform-browser-dynamic
    295 error
    295 error Fix the upstream dependency conflict, or retry
    295 error this command with --force or --legacy-peer-deps
    295 error to accept an incorrect (and potentially broken) dependency resolution.
    296 error
    296 error
    296 error For a full report see:
    296 error C:\Users\gkheysin\AppData\Local\npm-cache\_logs\2024-01-29T18_15_52_374Z-eresolve-report.txt
    297 verbose exit 1
    298 timing npm Completed in 6466ms
    299 verbose unfinished npm timer reify 1706552154219
    300 verbose unfinished npm timer reify:loadTrees 1706552154221
    301 verbose unfinished npm timer idealTree:buildDeps 1706552154236
    302 verbose unfinished npm timer idealTree:#root 1706552154236
    303 verbose code 1
    304 error A complete log of this run can be found in: C:\Users\gkheysin\AppData\Local\npm-cache\_logs\2024-01-29T18_15_52_374Z-debug-0.log
    'Log files:
    # npm resolution error report
    Attempts to update schematics failed
    C:\_ngIG\RepoPack01>ng update @igniteui/angular-schematics
    Using package manager: npm
    Collecting installed dependencies...
    Found 0 dependencies.
    Package '@igniteui/angular-schematics' is not a dependency.
    Angular version :
    ngular CLI: 17.1.1
    Node: 20.10.0
    Package Manager: npm 10.2.3
    OS: win32 x64
    Angular:
    Package Version
    @angular-devkit/architect 0.1701.1 (cli-only)
    @angular-devkit/core 17.1.1 (cli-only)
    @angular-devkit/schematics 17.1.1 (cli-only)
    @schematics/angular 17.1.1 (cli-only)
    so I deleted previous runs.. and started from the beginning
    still not working.. what should I do .. attached logs and created package & angular JSON files
    The ng new xxxx would create project with no problem..
    angular.txt
    	"$schema": "./node_modules/@angular/cli/lib/config/schema.json",
    	"version": 1,
    	"newProjectRoot": "projects",
    	"projects": {
    		"repo-pack01": {
    			"projectType": "application",
    			"schematics": {
    				"@schematics/angular:component": {
    					"style": "scss"
    			"root": "",
    			"sourceRoot": "src",
    			"prefix": "app",
    			"architect": {
    				"build": {
    					"builder": "@angular-devkit/build-angular:application",
    					"options": {
    						"outputPath": "dist/repo-pack01",
    						"index": "src/index.html",
    						"browser": "src/main.ts",
    						"polyfills": [
    							"zone.js"
    						"tsConfig": "tsconfig.app.json",
    						"inlineStyleLanguage": "scss",
    						"assets": [
    							"src/favicon.ico",
    							"src/assets"
    						"styles": [
    							"src/styles.scss"
    						"scripts": [
    							"./node_modules/hammerjs/hammer.min.js"
    						"stylePreprocessorOptions": {
    							"includePaths": [
    								"node_modules"
    					"configurations": {
    						"production": {
    							"budgets": [
    									"type": "initial",
    									"maximumWarning": "500kb",
    									"maximumError": "1mb"
    									"type": "anyComponentStyle",
    									"maximumWarning": "2kb",
    									"maximumError": "4kb"
    							"outputHashing": "all"
    						"development": {
    							"optimization": false,
    							"extractLicenses": false,
    							"sourceMap": true
    					"defaultConfiguration": "production"
    				"serve": {
    					"builder": "@angular-devkit/build-angular:dev-server",
    					"configurations": {
    						"production": {
    							"buildTarget": "repo-pack01:build:production"
    						"development": {
    							"buildTarget": "repo-pack01:build:development"
    					"defaultConfiguration": "development"
    				"extract-i18n": {
    					"builder": "@angular-devkit/build-angular:extract-i18n",
    					"options": {
    						"buildTarget": "repo-pack01:build"
    				"test": {
    					"builder": "@angular-devkit/build-angular:karma",
    					"options": {
    						"polyfills": [
    							"zone.js",
    							"zone.js/testing"
    						"tsConfig": "tsconfig.spec.json",
    						"assets": [
    							"src/favicon.ico",
    							"src/assets"
    						"styles": [
    							"src/styles.scss"
    						"scripts": []
    package.txt
      "name": "repo-pack01",
      "version": "0.0.0",
      "scripts": {
        "ng": "ng",
        "start": "ng serve -o",
        "build": "ng build",
        "watch": "ng build --watch --configuration development",
        "test": "ng test"
      "private": true,
      "dependencies": {
        "@angular/animations": "^17.0.0",
        "@angular/common": "^17.0.0",
        "@angular/compiler": "^17.0.0",
        "@angular/core": "^17.0.0",
        "@angular/forms": "^17.0.0",
        "@angular/platform-browser": "^17.0.0",
        "@angular/platform-browser-dynamic": "^17.0.0",
        "@angular/router": "^17.0.0",
    	"hammerjs": "^2.0.8",
        "igniteui-angular": "~17.0.0",
        "minireset.css": "~0.0.7",
        "rxjs": "~7.8.0",
        "tslib": "^2.3.0",
        "zone.js": "~0.14.2"
      "devDependencies": {
        "@angular-devkit/build-angular": "~17.0.0",
        "@angular-eslint/builder": "^17.0.0",
        "@angular-eslint/eslint-plugin": "^17.0.0",
        "@angular-eslint/eslint-plugin-template": "^17.0.0",
        "@angular-eslint/schematics": "^17.0.0",
        "@angular-eslint/template-parser": "^17.0.0",
        "@angular/cli": "~17.0.0",
        "@angular/compiler-cli": "~17.0.0",
        "@types/jasmine": "~5.1.1",
        "@typescript-eslint/eslint-plugin": "6.9.1",
        "@typescript-eslint/parser": "6.9.1",
        "eslint": "^8.52.0",
        "@igniteui/angular-schematics": "~17.1.1314",
        "jasmine-core": "~5.1.0",
        "karma": "~6.4.0",
        "karma-chrome-launcher": "~3.2.0",
        "karma-coverage": "~2.2.0",
        "karma-jasmine": "~5.1.0",
        "karma-jasmine-html-reporter": "~2.1.0",
        "typescript": "~5.2.2"
