we are using the infragistics grid on a page and the content of last row is hidden by the horizontal scroll bar in chrome but its not hiding the row in IE.
below are the attached pics for that. ANy idea of how to overcome this?
Hello Nirmala,
You can configure the height property of the WebDataGrid, or use paging to set a specified number of rows to prevent hiding rows.
You can check the following forum threads for more information about vertical and horizontal scrolling:
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-asp-net/105624/webdatagrid-show-vertical-scrollbar-when-it-isn-t-necessary
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-asp-net/41683/can-the-webdatagrid-scroll-horizontally
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-asp-net/110724/how-to-disable-the-scrollbar-in-webdatagrid
Svetla Boykova
we are using the ASP.NET Web Datagrid V12.2. I don't have an isolated Sample. This page is part of a bigger application.
Can you provide more information about the product name and the version you are using in your application? Do you use the Infragistics ASP.NET WebDataGrid or Javascript grid – igGrid?
It will help as well if you can provide a small, isolated sample application that demonstrates the behavior you are seeing.
Let me know if I may be of further assistance.
