We want collapse other rows if one row is expanded in our hierarchichal grid.
I was looking intothis post https://ko.infragistics.com/community/forums/f/ignite-ui-for-javascript/94943/collapse-other-rows-if-one-row-is-expanded
But solution given there is for Javascript, We need solution for MVC infragistic grid.
Hello Atul,
Only handling rowExpanding event for the igHierarachicalGrid is enough for achieving your requirement. I mentioned the dataBount event since you added a snippet in your previous response. Basically, what I am suggesting is handling the roxExpanding event with the correct id. This should be sufficient. For example:
$(document).delegate("#gridLoadOnDemand", "ighierarchicalgridrowexpanding", function (e, args) { var grid = args.owner, expandedRows, i; expandedRows = $(args.parentrow).closest('tbody').find('tr[state=e]'); for (i = 0; i < expandedRows.length; i++) { grid.collapse(expandedRows[i]); } console.log(args); });
Attached you will find a small sample illustrating my suggestion for your reference. Please test it on your side and let me know if you need any further assistance with this matter.
4722.HGrid_Updating_SaveChanges.rar
Hi Vasya,
I just quoted the code here for your reference , so id mismatched but now I get confused from your answer.
1. You have quoted the link above for rowExpanding , there ighierarchicalgridrowexpanding is the second parameter. I have tried this but was not working.
2. I had tried "iggriddatabound" as well but it was also not working.
3. Are you saying I have to use both event $(document).delegate("#grid", "iggriddatabound"... and $(document).delegate("#grid", "ighierarchicalgridrowexpanding"....
Thanks & Regards,
Atul
In the provided code snippets I noticed:
What I can suggest is try defining the event handlers consistently, with the same id and correct arguments order. For example, if we assume that the grid id is "grid" they should look like the following:
$(document).delegate("#grid", "iggriddatabound", function (e, args) { var grid = args.owner, expandedRows, i; expandedRows = $(args.parentrow).closest('tbody').find('tr[state=e]'); for (i = 0; i < expandedRows.length; i++) { grid.collapse(expandedRows[i]); } console.log(args); }); $(document).delegate("#grid", "ighierarchicalgridrowexpanding", function (e, args) { debugger; var grid = args.owner, expandedRows, i; expandedRows = $(args.parentrow).closest('tbody').find('tr[state=e]'); for (i = 0; i < expandedRows.length; i++) { grid.collapse(expandedRows[i]); } console.log(args); });
Please test this on your side and let me know whether it works on your side.
This is not working .
When I applied below code :
Then args.parentrow is undefined and when I applied the rowExpanding event from the link you provided then it is not hitting.
I am applying code like below :
$(document).delegate("ighierarchicalgridrowexpanding","#igGrid1", function (e, args) { debugger; var grid = args.owner, expandedRows, i; expandedRows = $(args.parentrow).closest('tbody').find('tr[state=e]'); for (i = 0; i < expandedRows.length; i++) { grid.collapse(expandedRows[i]); } console.log(args); });
Please provide me a sample code.
The same solution, as suggested in the Tsanna`s forum post, can be applied in MVC scenario as well. What needs to be done is to attach the rowExpanding event handler to the igHierarcicalGrid in the Index.cshtml file. The only difference is that you will add the event handler after the grid`s initialization. For example:
<body> @(Html.Infragistics() .Grid(Model) .ID("grid") .Width("100%") .Height("500px") .PrimaryKey("ID") .AutoGenerateColumns(false) .AutoGenerateLayouts(false) .Columns(column => { column.For(x => x.ProductName).HeaderText("Product Name").Width("30%"); column.For(x => x.CategoryName).HeaderText("Category").Width("30%"); column.For(x => x.UnitPrice).HeaderText("Unit Price").Width("20%").Template(" {{if parseInt(${UnitPrice}) >= 3 }} $ ${UnitPrice} <img width='10' height='15' src= 'https://www.igniteui.com/images/samples/templating-engine/colTemplateWithConditionalCell/arrowUp.gif' />{{else}}<img width='10' height='15' src= 'https://www.igniteui.com/images/samples/templating-engine/colTemplateWithConditionalCell/arrowDown.gif' />{{/if}}"); column.For(x => x.UnitsInStock).HeaderText("Units In Stock").Width("20%"); }) .Features(features => { features.Sorting().Type(OpType.Remote); features.Paging().Type(OpType.Remote); features.Filtering().Type(OpType.Remote); features.Responsive().ColumnSettings(cs => { cs.ColumnSetting().ColumnKey("CategoryName").Classes("ui-hidden-phone"); cs.ColumnSetting().ColumnKey("UnitPrice").Classes("ui-hidden-phone ui-hidden-tablet"); }); }) .DataSourceUrl(Url.Action("GetData")) .Render() ) <script> //Delegate $(document).delegate("#grid", "iggriddatabound", function (e, args) { var grid = args.owner, expandedRows, i; expandedRows = $(args.parentrow).closest('tbody').find('tr[state=e]'); for (i = 0; i < expandedRows.length; i++) { grid.collapse(expandedRows[i]); } console.log(args); }); </script> </body>
Please test this approach on your side and let me know if you have any additional questions regarding this matter.
