Is there any way to add a time stamp to the file that is being uploaded?
I have noticed that the files get replaced directly if they exist on the Uploads folder.
So, I think the best way to over come this situation would be to add a time stamp for the file being uploaded.
Mohammed Hafeezuddin
Hi Mohammed,
yes, definitely. this is not something that is done automatically, but you can easily achieve it using server-side events in your MVC controller code (or in Global.asax). For example you can have the following code which will cancel storing the file with its original filename, and will save it in a custom location that you specify, including a new custom filename.
The upload control always saves files in a unique temporary file name first, before renaming them to the original filename sent from the client. Using this event you can control what happens with the temporary file name and where it gets stored and under what final filename.
(the temp file always gets deleted, for sure, after the UploadFinishing has fired).
[ActionName("multiple-upload")] public ActionResult MultipleUpload() { UploadProgressManager.Instance.AddFinishingUploadEventHandler("serverID1", new EventHandler<UploadFinishingEventArgs>(handler)); return View("MultipleUpload"); } protected void handler(object sender, UploadFinishingEventArgs args) { string filePath = String.Format("{0}{1}", args.FolderPath, args.TemporaryFileName); if (System.IO.File.Exists(filePath)) { try { System.IO.File.Copy(filePath, "C:\\something.pdf"); } catch (Exception ex) { } } args.Cancel = true; }
Hope it helps. Thanks,
Angel
By the way, in the above sample code, "serverID1" is the "ControlId" property value of the control. It's a unique identifier (globally across pages) for that file upload so that the server-side module can match the handler with the actual upload control . This is not the ID of the actual HTML element on the page, because you may have many pages with different uploads, and the module which fires events is global for all upload operations.
Hi Angel,
in your sample code you state that "serverID1" is the ControlID of the upload control. if this is not the id attribute of the HTML element, how can i find out the controlID, or should i leave it as "serverID1"
i am using the igUpload control via javascript only and not razor or aspx implementation
Michael
Hi Michael,
ControlID should be set in uploadcontrol when you want to use server-side events. It is important to set unique ID for the whole application. For instance if you have instantiated one igUpload widget in Page1.aspx and another one in Page2.aspx then our advice is to set unique identifiers for both - according to naming convention you prefer. E.g. for those in Page1.aspx page1_uploader1 and for Page2.aspx to be page2_uploader1. Do not set them when using WebUpload for asp.net because these IDs are set automatically.
Miro Hristov
