290
igGrid Updating issues
We're using NetAdvantage for jQuery in an MVC2 environment. We have a Grid with row editing enabled, and ShowDoneCancelButtons set to false. All editable cells are numeric, so we're using the built in numeric editors.  We're having a few issues and would like some assistance in resolving them:
1. Your documentation states that the 'Enter' key should trigger the EndUpdating event, and that 'Esc' should cancel it. However, it doesn't work unless we push 'Ctrl-Enter' or 'Ctrl-Esc'. Am I missing a setting?
2. To populate the grid, we are passing an IQueryable collection of complex objects. This fails if we create a GridModel and pass it to the view along with the data. It succeeds is we 'GET' an empty model, and then 'POST' and set the grid's DataSource to a JsonResult. This is less efficient than we would like
3. We would like to batch updates and are using the example shown @ https://www.igniteui.com/grid/basic-editing as a basis for our coding. After the post back, I can see the data for the 'dirty' rows in the ig_transactions request key, however, calling model.GetTransaction() does not  populate embedded complex types (such as Foo.Bar.Foobar), and all embedded complex objects are set to initialized values instead of reflecting those being sent back from the UI.
Any assistance you could offer would be appreciated.
Bob
