Which version of IE does IGniteUI support? I include the modernizer: <script src="Scripts/modernizr.min.js"></script> but it seems the property is not set. I am running IE 9.0
Hi there,
We have removed dependency on $.browser in the 13.1. What version/build of the product are you currently using?
Thanks you for using the Infragistics forums!
Is there any resolution to this? I am using jQuery1.9.1 and I am getting the following error in both IE10 and latest Chrome.
JavaScript runtime error: Unable to get property 'msie' of undefined or null reference
I can confirm that Jquery 1.9.0 and 1.9.1 does not worklatest ver. that Works is 1.8.3
Hello Richard,
They should work as expected in the IE9.Which version of jQuery are you using? If you’re using JQuery 1.9.0 then that’s what’s causing the issue. Since there are numerous changes introduced in version 1.9 of jQuery it will take some time until our controls are fully compatible with it.
Let me know if that’s the jQuery version that you’re using.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
