I'm a bit new to KO, so I apologize. I have practically copied the example used here: http://ko.infragistics.com/products/jquery/sample/grid/grid-knockoutjs-integration
If I load up the object (referred to by db in the sample code) then the grid will initialize with all of the data properly.
If I put the ajax call in a function and bind it to a button, I can't get the data in the grid to load/refresh after the call. I've made sure that the ajax call is being made and the JSON is coming back. Is there another API I need to hook into the grid to refresh the data?
I have got a similar problem. I am trying to reload a grid using an AJAX call to an ASP.NET service. The service provides me with the new grid data. I tested this by adding another record using a second instance of the page. When I press the reload button I made, I can see the AJAX request and it actually returns the data including the new record I added.
So in my code I use knockout mapping to convert the JSON into an knockout ViewModel and set my ViewModel with the converted object.
MYNAMESPACE.gridFunctions.prototype.refresh = function (data) { if (data == undefined) { $(".ajax-loader").css("display", "block"); MYNAMESPACE.gridFunctions.prototype.read(undefined, MYNAMESPACE.gridFunctions.prototype.refresh) return; } MYNAMESPACE.mainViewModel = ko.mapping.fromJS(data); ko.applyBindings(MYNAMESPACE.viewModel); $(".ajax-loader").css("display", "none"); };
The read funtion gets a JSON string using JQuerys AJAX method. It all seems to be working fine but when I use ko.applyBindings() my grid stays the same even when my ViewModel has in fact changed (when I check it manually using the console)
Am I forgetting something?
EDIT:
I was using MYNAMESPACE.mainViewModel to set it, but this doesn't work because I was trying to use it as a pointer which of course it isn't.
EDIT2:
I had to use JQuery.parseJSON() to avoid an error from JQuery, I don't know why exactly, but it said there was an error in the JSON syntax.
MYNAMESPACE.viewModel.books = ko.mapping.fromJS($.parseJSON(data));
Hi Alex,
Could you provide me with small sample where this issue present so I could research it further.
Thanks in advance.
Sorry to keep replying. Interestingly, I got it to the point where that error only gets thrown the first time I make the call. Subsequent calls work just fine, and the grid updates (well, I can see the total rows is going up but no columns appear).
Ah, I seem to be erroring out before I can get to the rebinding.
I have this in the console: Uncaught TypeError: Cannot read property 'null' of undefined (thrown by the ig.grid knockout-extension).
The line that throws this error is from inside the viewmodel when I make the AJAX call:
success: function (data) { self.shows.removeAll(); $.each(data, function (key, val) { self.shows.push(val); <--- error });
The data coming back from the call is one big object, some of the properties are null (would that cause this?).
self.shows is an observableArray
Apologies Elena,
I was out all week last week. I'll be testing this again starting in a few minutes and let you know.
