I use the hierarchical grid and in your documentation your specify :
"Both the igGrid and igHierarchicalGrid controls feature data updating in the grid. The updating features of the grid provide a wide array of adding and editing values of the underling set of data bound to the grid",
but I was unable to find a way to get this array.
Can you tell me how can I get it please.
Regards.
Hello Maya,
Sorry I forgot to answer, yes it works.
Thank you.
Hello Cosoluce_Stones ,
I’m just following up to see if you’ve been able to resolve your issue. If you have any questions or concerns or if you need further assistance please let me know.
Best Regards,
Maya Kirova
Developer Support Engineer
Infragistics, Inc.
Hello Cosoluce,
Thank you for your patience while I was looking into this.
The hierarchical grid is composed of multiple igGrids for each level of the hierarchy. So if you want to get the transactions for a specific child grid you’ll need to get that child grid instance and get its transactions. You can get all child grid elements for the hierarchical grid using the allChildren method:
var hierarchicalGridChildren = $(".selector").igHierarchicalGrid("allChildren");
This will return a list with all the child grids. Once you get a specific child you can get its transactions via the allTransactions of that child grid. For example:
var transactions = $(specificChildGrid).igGrid("allTransactions");
Developer Support Engineer II
Hi Maya,
Did you find a solution for my issue ?
Effectively I misunderstood the documentation and it is the pending transactions I would. I tried on the hierarchical grid but both the "pendingTransactions" and "allTransactions" methods return an empty array. I tried on the normal grid and it works.
How can I get those transactions on a hierarchical grid ?
