385
Various virtualization problems
i'm facing some problems while using your Grid (virtualization mode: fixed)
- When filling the grid with a lot of rows (100000) Internet Explorer 10 doesn't show them all, i can only scroll to ~25000 (depending on row height i think).
- The avgRowHeight causes a lot of confusion for me. The value set, isn't always the exact height the rendered row has. I can't really figure out why. Also setting the avgRowHeight to a bad value (I guess when the scroll containers height isnt divisible by row-height or so) leads to some rows to be cut of at the end. At least i can not scroll to them. The problem is, the font(size) should be set dynamically later, also there might be multi-line (wrapped) text, so i can't set an always-working default avgRowHeight. that fits all situations.
- How does VirtualScrollTo work? I guess that the value passed to it is the desired row-index. When calling it with low values (1-10), the expected row is in the view-area. But the further i go down, the bigger the offset from the row wiith index X is. Or am i using the method in a wrong way?
- Cancelling the edit-mode by clicking on any other row in the grid, makes it impossible to re-enter edit mode (clicking on cell doesn't do anything).
edit:Found out that the edit-mode behaviour only apperas when RowSelectionMode is set to SingleRowSelection. Looks like the value of "this._waitSel" in "infragistics.ui.grid.updating.js" is never resetted, thus preventing the grid from entering editmode. Manually resetting the value works, but i'm quite unsure whether this has other impacts on the grid-behaviour. Also I don't like these kind of dirty hacks.
Thanks in advance
Lorenz
