Hi
I am (still) creating my first ASP.NET MVC 4 website and am using the igGrid on one of my pages.
I have the grid updating via the UpdateURL property - I can carry out CRUD operations on grid data without a hitch, I even get the IDs for new rows returned to grid rows.
I now need to have some other fields on the same page and I need to update them at the same time that I update the grid.
The fields are set up against properties in my model but I can't figure out how to access the model properties from the controller method that runs via UpdateURL.
Is this possible and, if so, can you give me a pointer as to how? As far as I can tell the controller method does not have access to the page's Model and neither does the GridModel.
It feels like I missing something obvious to the more experienced.
Graeme
I have had to settle for a two stage update process (shame I can't get it all into a transaction) by implementing the post back of the form on which the grid & other textboxes lie in addition to using the UpdateURL to save the grid data.
One Save button press will carry out a post back of the text box data and also action the UpdateURL controller method to save the grid data.
Untidy, but will have to do for now. There must be a better way, but I can't find it.
Hi Graeme,
I am updating this to let you know I am researching and working on a sample to help demonstrate a method to achieve this.
I will need a little more time to look into this. I will have another update for you by Wednesday.
Please see the sample I have attached which demonstrates how you can consolidate all your transactions into one post.
I call $.post with the SaveAllTheChanges route, which takes the formatted data and updates the data from the grid and also provides information from your form inputs.
In the response, I send back "Success" equal to true, which the grid requires to finish updating on the client side through the _saveChangesSuccess method. I also return a "result" that the formSuccess method uses to set our textbox's value.
If you have any further questions or concerns with this, please let me know.
Hello Graeme,
Please let me know if you need further assistance with this issue.
Hi Michael
Thanks for this. I am having trouble getting your sample to run up - stuck with a problem with the reference to Newtonsoft.JSON. I can't add the reference because version 4.5 "is incompatible" with .NET framework 4.0...even though I have just such a reference in my own .NET 4.0 app.
I want to use batch updates so I will try putting my post behind a button rather than the editRowEndedHandler.
I will post later with my results.
Thanks for the update. You seem to have figured it out, but most of the code that is used within the pages of the sample should port over without needing to run the sample. HomeController and its Index view are the files where everything happens.
If you any further questions or concerns with this, please let me know.
Please let me know if you still need help with this issue.
I has taken me a while to get back to this but I can at last confirm that the example you provided works nicely. Thank-you very much for your help.
Please let me know if you have any other questions or concerns about this issue and I'll be glad to help you.
You can always find more information on how to set up our controls in our documentation. Our documentation points out how you should configure the HTTP handler and module for IIS6 and IIS7 here:
http://help.infragistics.com/doc/jQuery/2013.1/CLR4.0?page=igUpload_Overview.html
http://help.infragistics.com/doc/jQuery/2013.1/CLR4.0?page=igUpload_Using_HTTP_Handler_and_Modules.html
As for my sample, you can enable NuGet package restore for the solution and NuGet will download the standard required packages. Afterwards, you will need to update the project References to the Infragistics.Web.Mvc.dll to the version you have installed and maybe update the javascript and Css references in my Home/Index view. If this still does not work, the Home controller and its views along with my model I created for it should be easily portable into another running project.
Once you get back to this and if you need further assistance, please let me know.
I couldn't get it to work. To be honest I am finding myself in this position often.
It takes a while to get the right info from your resources as it is spread across more than one resource - eg I couldn't get your example to run up so I have to try to move the right bits into my app and then play spot the difference with all related files in both projects. I usually get there in the end but have had to work on other aspects of my system for the time being. I will come back to it as it seems straight forward.
For another example - I was trying to get the file upload to work recently and found it a real struggle until I stumbled across a forum post that said I had to put an entry into my web.config for the module "IGUploadModule" to register it for IIS6. It would be good for the sample to mention this, at the top, in red, as I wasted hours looking for the answer.
I had it in system.webserver (This is where it needs to be for production) but it had to be in system.web for development. I probably haven't read the right "starter" documentation.
I'm sure that it is something similar preventing me from getting this going so I have not given up and will return to it later.
Once I get each widget working they are most excellent so I am very pleased to have them in my arsenal.
