Hi
I recently updated infragistic library with 13.1.20131.2292 and i am facing a problem with infragistic summary feature in french language.
After upgrading to 13.1.20131.2292 version i am seeing that in grid summary row sum is coming by multiplying by 100 but if i load the same grid in English its showing correct sum. before this version i was using 13.1.20131.2039 version and in this version this problem was not there even i checked this problem in latest version 13.2 also and problem is exist there also.
for your reference i am attaching screen shots for you with both version you can see the difference there.
Hello Vivek,
Did you have the time to try the new service release and see if it fixes your issue?
Hi Vivek,
I created case CAS-128187-L3H9K3 for you and will update you through it about this issue.
You could see it in your account in the 'Support Activity' page.
Thank you.
HI Martin
Thanks For you quick Help Its works for Thanks a lot.
Vivek
I'm sorry to say it, but we identified this issue as a regression in our codebase. I've logged an internal bug with id: 158820. We will fix it for the next service release. You'll get notified when this happens. Until then as a workaround I'm attaching to this forum post a patched (fixed) version of the summaries file which you should place in the "JS\infragistics\js\modules" of your sample attached to this forum thread.
Hope this helps,Martin PavlovInfragistics, Inc.
I have attached one poc with two html file for french and english if you run html and english html file you can clearly see the problem.
Please help me on this problem in urgent basis because its creating a serious bug on my project and stoping me production deliverable.
Thanks in advance
