140
Regarding combo box property
When I am selecting value in a combo box it is working properly. After the selection, when I move my cursor on the selected text of the combo box, the text is not remaining constant  that is text is not displaying. when I move out the cursor from the combo box again the text is displaying. can you please sort out this problem for me. Here I am sending you the code which I have used.
<style type="text/css">
input.button-style {
margin-top: 10px;
.ui-iggrid th, .ui-iggrid th.ui-state-default, .ui-iggrid th.ui-state-hover, .ui-iggrid th.ui-state-active {
text-align: left;
white-space: pre-wrap;
div#layout {
background-color: #777;
padding: 15px;
border-radius: 5px;
/*border-top-left-radius: 5px;
border-top-right-radius: 5px;
border-bottom-left-radius: 5px;
border-bottom-right-radius: 5px;*/
div#layout .left p, div#layout .right p, div#layout .center p, div#layout h3 {
margin: 15px;
div#layout .center {
background-color: #EEE;
color: #555;
div#layout .right {
background-color: #555;
color: #EEE;
border-radius: 5px;
div#layout .left {
padding-left: 20px;
border-radius: 10px;
div#layout .header {
background-color: #2CBDF9;
div#layout .footer {
.hidden {
display: none !important;
.ui-datepicker {
width: 360px;
</style>
@section Body {
<h2>@ViewBag.Title</h2>
<script>
currencies = @Html.Raw(Json.Encode(Model.Currencies));
components = @Html.Raw(Json.Encode(Model.Components));
function formatCurrency(val) {
var i, item;
for (i = 0; i < currencies.length; i++) {
item = currencies[i];
if (item.Id === val) {
val = item.CurrencyCode;
return val;
function formatComponent(val) {
var i, item;
for (i = 0; i < components.length; i++) {
item = components[i];
val = item.SumitomoPartNumber;
return val;
</script>
<fieldset>
<div id="layout" style="width: 100%; height: 760px; display: block">
<div id="livepricereportdiv" class="left" style="width: 100%">
<br />
@using (Html.BeginForm("ExportToExcel", "CspModule", FormMethod.Post))
<table>
<tr>
<td><h4> Customer</h4></td>
<td>&nbsp;&nbsp;
@(Html.Infragistics().ComboFor(m => m.CustomerItem)
.ID("customerCombo")
.Width("270px")
.DataSource(Model.Customers)
.ValueKey("Id")
.TextKey("CustomerName")
.NullText("Select a Customer")
//.ValidatorOptions(options => options.OnBlur(false).OnChange(false).OnSubmit(true).BodyAsParent(false))
.DataBind()
.Render()
</td>
</tr>
<tr>
<td>
<h4> Project</h4>
</td>
<td>
@(Html.Infragistics().ComboFor(m => m.ProjectItem)
.ID("projectCombo")
.Width("270px")
.DataSource(Model.Projects)
.ValueKey("Id")
.TextKey("ProjectCode")
.NullText("Select a Project")
.DataBind()
.Render()
</td>
</tr>
</table>
<br />
@*<legend>Export Format</legend>
<input type="radio" id="CurrentPage" name="exportType" value="false" checked="checked" />
<label for="CurrentPage">Current Page</label>
<input type="radio" id="AllPages" name="exportType" value="true">
<label for="AllPages">All Pages</label>*@
<input type="submit" id="exportsubmit" value="Export To Excel" />
<br /><br />
</div>
<br />
<div id="LivePricesGrid">
@(Html.Infragistics().Grid(Model.ComponentSalesPrices.AsQueryable())
.ID("LivePricesGrid")
.Width("100%")
.Height("500px")
.PrimaryKey("Id")
.AutoGenerateColumns(false)
.AutoGenerateLayouts(false)
.RenderCheckboxes(true)
.AutoAdjustHeight(true)
.Columns(column =>
column.For(x => x.Id).HeaderText("Id").Hidden(true);
column.For(x => x.ComponentId).HeaderText("Component").FormatterFunction("function(val) { return formatComponent(val); }");
column.For(x => x.EffectiveStartDate).HeaderText("Effective Start Date");
column.For(x => x.EffectiveEndDate).HeaderText("Effective End Date");
column.For(x => x.CurrencyId).HeaderText("Currency").FormatterFunction("function(val) { return formatCurrency(val); }");
column.For(x => x.SellingPrice).HeaderText("Selling Price");
.Features(features =>
features.Sorting().Type(OpType.Local);
features.Paging().Type(OpType.Local);
//features.Filtering().Type(OpType.Local);
features.Selection().Mode(SelectionMode.Row);
features.Tooltips()
.Visibility(TooltipsVisibility.Always)
.ColumnSettings(cs =>
cs.ColumnSetting().ColumnKey("ComponentId").AllowTooltips(true);
cs.ColumnSetting().ColumnKey("EffectiveStartDate").AllowTooltips(true);
cs.ColumnSetting().ColumnKey("EffectiveEndDate").AllowTooltips(true);
cs.ColumnSetting().ColumnKey("CurrencyId").AllowTooltips(true);
cs.ColumnSetting().ColumnKey("SellingPrice").AllowTooltips(true);
.Style(TooltipsStyle.Tooltip)
.ShowDelay(100);
.DataSourceUrl(Url.Action("GetLivePricesbyCustomerIdandProjectId"))
.DataBind()
.Render()
<input type="hidden" name="pageSize" id="pageSize" value="" />
<input type="hidden" name="pagenumber" id="pageNumber" value="" />
</div>
</div>
</fieldset>
<script>
$(function () {
var grid = $("#LivePricesGrid"),
pageSize = $("#pageSize"),
pageNumber = $("#pageNumber");
pageNumber.val(0);
pageSize.val(0);
grid.on("iggridrendered", function (e, ui) {
pageSize.val(grid.igGridPaging("option", "pageSize"));
pageNumber.val(grid.igGridPaging("option", "currentPageIndex"));
grid.on("iggridpagingpageindexchanged", function (e, ui) {
pageNumber.val(ui.pageIndex);
grid.on("iggridpagingpagesizechanged", function (e, ui) {
pageSize.val(ui.pageSize);
pageNumber.val(0);
$("#exportsubmit").igButton({ labelText: $("#exportsubmit").val() });
</script>
<script>
var updates, loadingIndicator;
$(function () {
$.ui.igValidator.defaults.showAllErrorsOnSubmit = true;
$("#customerCombo").on("igcomboselectionchanged", function (e, args) {
var customerId = $("#customerCombo").igCombo("value");
var postData = { "CustomerId": customerId };
$.getJSON("/CspModule/GetProjectsbyCustomerId", postData, function (returnData) {
$("#projectCombo").igCombo("option", "dataSource", returnData);
$("#projectCombo").on("igcomboselectionchanged", function (e, args) {
var projectId = $("#projectCombo").igCombo("value");
var postData = { "CustomerId": customerId, "ProjectId": projectId };
$.getJSON("/CspModule/GetLivePricesbyCustomerIdandProjectId", postData, function (returnData) {
$("#LivePricesGrid").igGrid("option", "dataSource", returnData);
$('.validateOptions').attr('disabled', 'disabled');
</script>
