100
Composite Scatterline/Range Chart - Different xAxis Values
Everything I find on composite charts is about yAxis with different values. Is it possible to have a composite chart with different xAxis values. For example I have the chart declared in the code below. For each series in the scatterline portion of the chart I want to display a "range" (i.e. high/low) values for that series. The caveat is that the range values will always be xAxis values of 6, 12, 26, 52, 104 with whatever corresponding yAxis values. The scatter line data might be slightly different so in the code below the xAxis values are 7, 13, 22, 51, 101 with an interval of 8.
For the data would I simply add high/low values to the data array like the following? For now the values are hard coded for a demo but eventually we will be pulling them from a production SQL server database.
            var lineData = [
                    { "arg": 0.0, "val": 0.0, "high": 0, "low": 0 },
                    { "arg": 7, "val": 0.035, "high": 0.041, "low": 0.023 },
Any help would be appreciated. Thanks
Sample code:
    <div class="chartContainer">
        <div class="chart">
            <%--<h4>Scatter Line</h4>--%>
            <div id="chartScatterLine"></div>
        </div>
    </div>
    <!-- Custom Tooltip Template -->
    <script id="tooltipTemplateMedial" type="text/x-jquery-tmpl">
        <div style="color: #44ACD6">
            <span>Medial</span><br />
            <span>Exam Followup Week: </span><span>${item.arg}</span><br />
            Translation (mm): <span style="font-weight: bold">${item.val}</span>
        </div>
    </script>
    <script id="tooltipTemplateProximal" type="text/x-jquery-tmpl">
            <span>Proximal</span><br />
            Translation (mm): <span style="font-weight: bold">${item.prc}</span>
        </div>
    </script>
    <script id="tooltipTemplateLateral" type="text/x-jquery-tmpl">
            <span>Lateral</span><br />
            Translation (mm): <span style="font-weight: bold">${item.lat}</span>
        </div>
    </script>
        $(function () {
            function createScatterChart(selector, seriesType, dataSource) {
                $(selector).igDataChart({
                    width: "500px",
                    height: "400px",
                    legend: { element: "lineLegend" },
                    dataSource: dataSource,
                    title: "Stem Translation",
                    axes: [{
                        type: "numericX",
                        interval: 13,
                        title: "Week"
                        type: "numericY",
                        title: "Translation (millimeters)",
                        maximumValue: 1.5,
                        formatLabel: function (val) {
                            //var bVal = (val / 1000),
                            rounded = Math.round(val * 1000) / 1000;
                            return rounded;
                    series: [{
                        isDropShadowEnabled: true,
                        shadowOffsetX: 0,
                        shadowOffsetY: 3,
                        useSingleShadow: false,
                        shadowColor: "#666666",
                        type: seriesType,
                        xAxis: "xAxis",
                        yAxis: "yAxis",
                        xMemberPath: "arg",
                        yMemberPath: "val",
                        markerType: "circle",
                        showTooltip: true,
                        tooltipTemplate: "tooltipTemplateMedial",
                        thickness: 3,
                        title: "Medial"
                        shadowOffsetX: 0,
                        shadowOffsetY: 3,
                        type: seriesType,
                        xAxis: "xAxis",
                        yAxis: "yAxis",
                        xMemberPath: "arg",
                        yMemberPath: "prc",
                        showTooltip: true,
                        tooltipTemplate: "tooltipTemplateProximal",
                        thickness: 3,
                        title: "Proximal"
                        shadowOffsetX: 0,
                        shadowOffsetY: 3,
                        type: seriesType,
                        xAxis: "xAxis",
                        yAxis: "yAxis",
                        xMemberPath: "arg",
                        yMemberPath: "lat",
                        showTooltip: true,
                        tooltipTemplate: "tooltipTemplateLateral",
                        thickness: 3,
                        title: "Lateral"
                    horizontalZoomable: true,
                    verticalZoomable: true,
                    windowResponse: "immediate"
            var lineData = [
                    { "arg": 0.0, "val": 0.0 },
                    { "arg": 6, "val": 0.035 },
                    { "arg": 12, "val": 0.090 },
                    { "arg": 26, "val": 0.079 },
                    { "arg": 52, "val": .088 },
                    { "arg": 104, "val": .33 },
                    { "arg": 0.0, "prc": 0.0 },
                    { "arg": 6, "prc": -1.316 },
                    { "arg": 12, "prc": -1.301 },
                    { "arg": 26, "prc": -1.334 },
                    { "arg": 52, "prc": -1.23 },
                    { "arg": 104, "prc": -1.43 },
                    { "arg": 0.0, "lat": 0.0 },
                    { "arg": 6, "lat": -1.47 },
                    { "arg": 12, "lat": -1.512 },
                    { "arg": 26, "lat": -1.567 },
                    { "arg": 52, "lat": -1.725 },
                    { "arg": 104, "lat": -1.869 }
            createScatterChart("#chartScatterLine", "scatterLine", lineData);
    </script>
    <table>
        <tr>
            <td id="lineLegend" style="float: left"/>
        </tr>
    </table>
Parents Reply Children
