Hey guys,
I'm utterly confused by this. Every time I go to make a mobile prototype, either in iPhone 4 or iPhone 5, and I go to share it with someone from a link on your servers, it loads the first screen and then when I click one thing, I get "Oops! Looks like a screen is missing from the prototype." The files are saved within the same project folder and I have even tried this on PC and Mac. Same issue and not sure why. Here was the link and watch what happens when you click "announcements": http://indigo.infragistics.com/prototype/A84ASPED.html
Any ideas?
Charles
Hello Charles,
I am just checking whether you need additional assistance after the testing.
Hi guys,
I'm running the latest update. I "think" I figured it out but will keep trying it out today and early next week to see. What was confusing to me was I was saving it in the same project folder for the desktop app and because it was putting it into an iPhone subfolder, I thought that would work. When I made a separate project, outside of the other, it seemed to work. I thought they just had to be in the same folder and was confused as to why was only not working on the mobile prototypes. Like I said though, I'll try it again today and Monday and see if I run into issues.
Thanks for the quick responses!
Hi Charles!
When you share a prototype, you can either share the entire project, or just some files. If you only share some files, make sure to also include all the linked ones, otherwise, links to those screens will be broken. If you are selecting individual screens, please check if the Announcements1.screen was selected when sharing the start screen.
Let me know if that helps.
You can get additional info about sharing on the Sharing Your Prototypes topic on the Indigo documentation.
Thanks!
Santiago.
Indigo Studio Team.
Thank you for contacting our community.
Would you let me know if you are running the latest available update of Indigo Studio? You can check for updates by going to Menu->Help&About and then press the ‘Check For Updates’ button. There was an issue that caused similar behavior with missing screen and it is fixed with the latest version.
Would you also let me know if you get any warnings when you try to share the screens choosing ‘Share All in Project’ option?
