Today I opened up Indigo and it just sits at the initial loading screen. There's nothing out of the ordinary in my log file. Any assistance with this would be very helpful. Thank you!
Hello Arthur,
Thanks for the email. I am glad everything is working now.
Sincerely,
Valerie
Developer Support Supervisor - XAML
www.infragistics.com/support
Thank you for the log files.
Since deleting the UserRoot.xml did not have any effect, after reviewing the log files we suggest you try the following
Please check that Indigo Studio was completely uninstalled by checking that the folder `C:\Users\<your user name>\AppData\Local\Infragistics\Indigo Studio` does not exist. If it exists, please delete it.
Open Indigo and browse and open a file from C:\Users\artur.makolagwa\Documents\Indigo
If you are still having issues after this, please send me the windows event log along with the indigo.log and win.log files. Again you can email these to me at support@infragsitics.com and include ATTN:Valerie in the subject.
Please delete the following file
C:\Users\<yourusername>\Documents\Indigo Studio\Settings\UserRoot.xml
and try to open Indigo and let me know if you are able to launch Indigo?
If you are not able to open Indigo after deleting the UserRoot file, could you please send me the log files? Log files are under:
Win -> C:\Users\<yourusername>\Documents\Indigo Studio\Logs
In addition to the log file, could you also please send me the event log and let me know which language you have.
If you are unable to attach the files to this thread, you may email them to support@infragistics.com and include ATTN: Valerie in the subject
Hi! My Indigo Lite also stucks on loading screen and it seems there's no way to fix that. I have Win7 SP1 x64 and at first I tried do reinstall Silverlight - nothing happened. Then I reinstalled Indigo itself - I had an older version (from 11/05/2013) installer and it worked. Then I updated Indigo in two steps - after first update it was working without problems (but I couldn't open files created before), but it stopped working after the second update (to the latest version).
Is there any way to fix it? I really like to continue using Indigo...
Thanks Tom, that seems like a completely different issue then.
Could you please send the log files located in the logs folder to indigo at infragistics.com?
Also, can you make sure the file located at Settings/win.settings on the Indigo Studio documents folder can be written to? (it shouldn't be failing because of that, but it's odd that Indigo is unable to write to the file).
Thanks!
Best regards,
Santiago.
Indigo Studio Team.
