Hi all,
I have a UltraWebGrid on a page and I need to format one column's cell values.
Pseudo Code: If the cell valus is 0<value<100, set the cell's fontcolor to red, else set it to green.here is the code I have tried on the RowDataBound event:
UltraGridRow thisRow = UltraWebGrid1.Rows.FromKey("GetPercentageAchieved");
else
Also here is the code for the column in question:
<igtbl:UltraGridColumn BaseColumnName="GetPercentageAchieved" Key="GetPercentageAchieved"
IsBound="True" DataType="System.Decimal" Format="N2" Width="25%">
<Header Caption="% Achieved">
<RowLayoutColumnInfo OriginX="3" />
</Header>
<Footer>
</Footer>
</igtbl:UltraGridColumn>
The error I get is on the RowDataBound event which says that i'm getting a null reference.
Therefore, my question is, how do I get the cell value of each row of a particular column on RowDataBound?
Thanks in advance.
allythacker said: if you look closer at the code you will see that my question is about the RowDataBound event. protected void UltraWebGrid1_DataBound(object sender, EventArgs e) { ....... }the list of properties available to me for the EventArgs is .GetHashCode(), .Equals(), . GetType(), .ToString() So e.Row..... is not going to work here.
protected
I don't know about C#, but in VB, the name "UltraWebGrid1_DataBound" usually handles the Grid.DataBound event, which fires after the entire grid is bound. And as far as I can see, there is no RowDataBound The Grid.InitializeRow fires once per row, and should give you access to one row at a time.
e.Row.Cells.FromKey("CELLID").Value
or
e.Row.Cells.FromKey("CELLID").Text
Thanks anyway.
try
e.Row.Cells.FromKey("GetPercentageAchieved").Text
thanks
