364
UltraWebGrid.copy() fails
I have been trying to get the copy() function to work for my WebGrid, but it keeps returning false.  Here is my javascript code for capturing the context menu:
function ShowContextMenu(evt){
//Firefox passes event arg as parameter (evt). If that is null, we'll use window.event (Internet Explorer proprietary)
var e=evt?evt:window.event;
//Call show menu with menuID
//specify clientX and clientY to get more accurate positioning for this particular layout
igmenu_showMenu("<%=this.muContextMenu.ClientID %>",null,(e.clientX+document.documentElement.scrollLeft)+"px",(e.clientY+document.documentElement.scrollTop)+"px");
//Firefox (W3C) - cancel event
if(typeof(e.preventDefault)=="function")e.preventDefault();
//InternetExplorer (Proprietary) - cancel event
e.returnValue=false;
return false;
function ContextMenuItemClick(menuid,itemid)
//Grab a reference to the ContextMenuItem that was clicked on
var item=igmenu_getItemById(itemid);
var oGrid = igtbl_getGridById("ugContacts");
var nRows = oGrid.Rows.length;
if(item!=null){
//We'll use the text from the menuitem to decide which operation to perform
switch(item.getText()){case "Select All":
oGrid.selectRowRegion(oGrid.Rows.getRow(0), oGrid.Rows.getRow(nRows-1));
break;
case "Copy":
oGrid.copy();
break;
case "Export To Excel":
document.getElementById("wibExport2Excel").click();break;
function ugContacts_MouseUpHandler(gridName, id, button)
if(button!=2){
//Because the WebGrid consumes all mouse events, we need to add
//a listener to determine when a mouse click has occured so we can
//close the popup menu appropriately
igmenu_getMenuById("<%= this.muContextMenu.ClientID %>").dismiss();
The "Select All" and "Export to Excel" functions properly, but the copy returns a false when I capture it's return value.
I have a WebGrid in a page, it is hierarchical, and I have CellClickActionDefault set to RowSelect.  Here is my UltraWebGrid setup:
<igtbl:UltraWebGrid ID="ugContacts" runat="server" Height="560px" Width="100%"
oninitializelayout="ugContacts_InitializeLayout"
OnDataBinding="ugContacts_DataBinding">
<Bands>
<igtbl:UltraGridBand>
<AddNewRow Visible="NotSet" View="NotSet"></AddNewRow>
</igtbl:UltraGridBand>
</Bands>
<displaylayout allowcolsizingdefault="Free" bordercollapsedefault="Separate"
name="UltraWebGrid1" rowheightdefault="-1px" selecttypecelldefault="Extended"
selecttypecoldefault="Extended" selecttyperowdefault="Extended" version="3.00"
viewtype="Hierarchical" CellPaddingDefault="5" ColWidthDefault="-1px" GridLinesDefault="None"
IndentationDefault="1" RowSelectorsDefault="No"
allowsortingdefault="OnClient" enableclientsiderenumbering="True"
enableinternalrowsmanagement="True" headerclickactiondefault="SortMulti"
sortcasesensitivedefault="False" CellClickActionDefault="RowSelect">
<framestyle backcolor="White" borderstyle="Solid" borderwidth="2px"
font-names="Microsoft Sans Serif" font-size="XX-Small" height="560px"
width="100%">
</framestyle>
<Images ImageDirectory="./ig_res/Default/images/">
<CollapseImage Url="igg_sortAsc.gif" />
<ExpandImage Url="igg_sortDesc.gif" />
</Images>
<RowAlternateStyleDefault Font-Names="Microsoft Sans Serif"
Font-Size="XX-Small" BackColor="#CCCCCC" BorderColor="#0144D0"
BorderStyle="None" BorderWidth="0px">
<Padding Left="3px" />
<BorderDetails ColorLeft="White" ColorTop="White" />
</RowAlternateStyleDefault>
<ClientSideEvents MouseUpHandler="ugContacts_MouseUpHandler" />
<pager>
<PagerStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
<borderdetails colorleft="White" colortop="White" widthleft="1px"
widthtop="1px" />
</PagerStyle>
</pager>
<headerstyledefault backcolor="Silver" borderstyle="Solid" font-names="Microsoft Sans Serif"
font-size="XX-Small" Font-Bold="True">
widthtop="1px" />
</headerstyledefault>
<rowstyledefault backcolor="White" bordercolor="#0144D0" borderstyle="None"
borderwidth="0px" font-names="Microsoft Sans Serif" font-size="XX-Small">
<padding left="3px" />
<borderdetails colorleft="White" colortop="White" />
</rowstyledefault>
<SelectedRowStyleDefault BackColor="#9FBEEB">
</SelectedRowStyleDefault>
<GroupByBox Hidden="True">
</GroupByBox>
<addnewbox>
<boxstyle backcolor="LightGray" borderstyle="Solid" borderwidth="1px"
Font-Names="Microsoft Sans Serif" Font-Size="XX-Small">
widthtop="1px" />
</boxstyle>
</addnewbox>
<activationobject bordercolor="" borderwidth="0px" allowactivation="False"
borderstyle="None">
</activationobject>
<AddNewRowDefault>
<RowStyle Font-Names="Microsoft Sans Serif" Font-Size="XX-Small" />
</AddNewRowDefault>
</displaylayout>
</igtbl:UltraWebGrid>
Am I missing something?  Do I have a setting improperly set?  Or is this not possible with hierarchical grids?
I appreciate any assistance.
Mark
