Is it possible to copy a pre existing grid on the page on a button press,my requirement is that a user presses a button and a copy of the current grid is creatd on the page along side the original grid.
Is there some way I can do that.?
I don't think if there is a dirrect way to achieve it because no cloning information is available for the grid. Also adding the grid on button click to the view (dynamically) is not feasible because you need to do all the stuff (adding exact column and datasource fetched from the existing grid).
Thank you
Roshan
Actually I think you can do this - but as Roshan says, you'll need the column names etc to get it right.
What exactly is this for? I can give you more edvice if I have a more detailed understanding of your needs.
Thanks,Jim
Yes you can - but please don't ask me to write out an example here, as it owuld be a little long.
If you look in the API for NetAdvantage you will find that all the components have server-side classes.
To create a grid dynamically, you would instantiate HtmlGridView and then add the columns etc. as needed.
On your web page you'll need a place holder tag into which the grids can be dropped, or you'll need to rewrite the page either through a full post-back or by manipulating the DOM via Javascript.
Best,Jim
Jim, thanks for confirming , I will certainly try creating a grid on the server which should not be very difficult.
However I am not clear on second part, actually rendering it on the page and creating a place for it, I will be very grateful if you could provide some sample code or point in the right direction.
regards,
Avijit
Avijit:
Sure. When you create a grid as a server-side object, its not really connected to the browser. So to get it to appear on the page, you have to connect it to a tag in teh JSP.
Since you're going to have several grids - and since the number of grids needs to change synamically, you're going to need a container object (like an h:panelGrid on your page. You must bind the panel to the server and then you can add your grids to the panel, as children.
When you add the panle to the page, be sire to use a binding attribute to connect it to a server-side attribute.
Jim:
I have been able to create a grid on the page dynamically using Java code, the problem I am facing now is that, since the no. of grids is not fixed I need to create a new data source at run time.
Although creating a Arraylist at at run time is not a problem , the problem comes as there are no getters/setters for the newly created list.
I will be highly obliged if you could give me some suggestions or pointers for solviong this problem.
Another query that I had is:
In a simple grid that I created, even when I edit the values of a cell, the setter for the list is never called but the edited values are always available in the list. Please tell me how this works.
Well, the ArrayList needs to be populated with Beans - the Grid will pull its columns from the getters and setters in the Bean, not in the ArrayList itself.
Then when you're building the grid, you will need to assign the attribute from the bean to a column. To do this use the setUnifiedValueExpression. This method is in the UnifiedColumn class, which is an ancestor of both HtmlColumn and Column.
HtmlColumn
Column.
Sure, but I want to make sure that I'm understanding the issue you're facing.
The grid gets its data from a collection type, usually an ArrayList. The ArrayList contains ordinary Java Beans - these are the objects that will provide you with your getters and setters. So when you said:
"Although creating a Arraylist at at run time is not a problem , the problem comes as there are no getters/setters for the newly created list."
I thought I should point out that the getters and setters aren't in the ArrayList object, they are in teh ebans that the ArrayList holds.
Is this the problem, or have I misunderstood you?
I could not understand clearly what you meant above.
Can u pls clarify a bit..??
