We have been using Infragistics 2006v1 for a few years without any issues. We recently renewed and updated our site to Infragistics 2009v2. After a day or so of uptime on our production server we start getting random exceptions with the infragistics controls. The exact exception that start it off is below. The only way to fix this is to do an IIS reset and then it will be stable for a day or so.
** Exception : Object reference not set to an instance of an object.
** Stack Trace : at
Infragistics.WebUI.Shared.GlobalCssHelper.GetPageContainer(Page page, Boolean create)
at Infragistics.WebUI.Shared.GlobalCssHelper.OnInit(WebControl
control, Page page)
at Infragistics.WebUI.WebDataInput.WebTextEdit.OnPreRender(EventArgs
e)
at System.Web.UI.Control.PreRenderRecursiveInternal()
at System.Web.UI.Page.ProcessRequestMain(Boolean
includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Pushkar,
I responded to this same post on another thread here. Please only post your questions once.
Hi Team,
We have recently upgraded from Infragistics Version=9.1.20091.2087, to Version=13.2.20132.2187. This issue was not there before, but now we have also started getting random errors on the same lines, which only get solves after recycling of app pool.
Stack trace: at Infragistics.WebUI.Shared.GlobalCssHelper.GetPageContainer(Page page, Boolean create)
at Infragistics.WebUI.Shared.GlobalCssHelper.OnInit(WebControl control, Page page)
at Infragistics.WebUI.WebSchedule.WebDateChooser.OnPreRender(EventArgs e)
Please look into this at high priority, and let me know if any license key details are needed.
Pushkar
ivmh2005,
I have created support case CAS-60666-TLGWNC to assist you with this. You’ll be able to access this case from the My Support Activity page:<https://ko.infragistics.com/my-account/support-activity/>
Let me know if you have any questions with this matter.
Hi Alan,
I have the same problem and wanted to know if you can send the files you mention and to replace or if you have other solution, because i have reset IIS every day or two day max. My e-mail is ivmh2005@gmail.com, ivmh_2002@hotmail.com.
Thought it was a mistake in my code, but reading about the subject I can see is an error of Infragistics, you can help me ASAP on this problem.
Hi Viktor,
