65
Error when using Infragistics 9.2
In one of the applications, we are using Infragistics controls ver 9.2 and from past few days, we are getting exceptions related to GlobalCSSHelper class, which might be taking the application down and IISReset is solving the problem on a temporary basis. Attached is the exception details from teh logs.
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 18/06/2012 16:05:38
Event time (UTC): 18/06/2012 15:05:38
Event ID: d4440248f4174c83911ab0ebd5e39d4d
Event sequence: 3446
Event occurrence: 9
Event detail code: 0
Application information:
    Application domain: /LM/W3SVC/1/Root/QuoteUI-1-129844720851215297
    Trust level: Full
    Application Virtual Path: /QuoteUI
    Application Path: C:\Projects\QuoteUI\
    Machine name: LONGMP001
Process information:
    Process ID: 4784
    Process name: w3wp.exe
    Account name: NT AUTHORITY\NETWORK SERVICE
Exception information:
    Exception type: NullReferenceException
    Exception message: Object reference not set to an instance of an object.
Request information:
    Request URL: http://gmpricer/quoteui/Renewals.aspx
    Request path: /quoteui/Renewals.aspx
    User host address: 172.17.29.13
    User: WREN\aengland
    Is authenticated: True
    Authentication Type: Negotiate
    Thread account name: NT AUTHORITY\NETWORK SERVICE
Thread information:
    Thread ID: 7
    Is impersonating: False
    Stack trace:    at Infragistics.WebUI.Shared.GlobalCssHelper.GetPageContainer(Page page, Boolean create)
   at Infragistics.WebUI.Shared.GlobalCssHelper.OnInit(WebControl control, Page page)
   at Infragistics.WebUI.WebSchedule.WebDateChooser.OnPreRender(EventArgs e)
   at System.Web.UI.Control.PreRenderRecursiveInternal()
   at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Can we know teh permanent solution for this. Whether any service Pack with version 9 is released in Infragistics which has solved this issue. Can you please help.
Parents Reply Children
No Data
