236
Sample: Turn WebCombo into multiselect Checkbox Combo
I had a need for a combobox that allowed multiselect and checkbox.  WebCombo was very close to what I needed, with some simple code i was able to achieve this functionality so i figured i would share with others who may be interested.
Steps:
Drop a webcombo on your form:
In page_load add the following code: ( I set properties in code for webcombo)
if (!IsPostBack)
//create datasource
DataTable tbl = new DataTable();
tbl.Columns.Add("Id", typeof(int));
tbl.Columns.Add("Checked", typeof(bool));
tbl.Columns.Add("Text");
for (int i = 0; i < 15; i++)
tbl.Rows.Add(
new object[ { i, false, "Test " + i });
WebCombo1.DataTextField =
"Text";WebCombo1.DataValueField = "Id";
WebCombo1.DataSource = tbl;
WebCombo1.DataBind();
//just some adjusting of the height
if (WebCombo1.Rows.Count > 5)
WebCombo1.DropDownLayout.DropdownHeight =
Unit.Pixel(110);
//get a reference to the grid in the combo
UltraWebGrid grid = (UltraWebGrid)WebCombo1.Controls[0];if (grid != null)
//set some properties of the grid to act and look like a combo
grid.Columns.FromKey("Checked").AllowUpdate = AllowUpdate.Yes;
grid.DisplayLayout.ClientSideEvents.CellClickHandler = "GridCellClickHandler";
grid.DisplayLayout.ClientSideEvents.AfterCellUpdateHandler = "GridAfterCellUpdateHandler";
grid.Columns.FromKey("Checked").CellStyle.BorderWidth = Unit.Pixel(0);
grid.Columns.FromKey("Text").CellStyle.BorderWidth = Unit.Pixel(0);
grid.DisplayLayout.ActivationObject.BorderStyle = BorderStyle.None;
grid.Columns.FromKey("Checked").Width = Unit.Pixel(15);
grid.Columns.FromKey("Text").Width = Unit.Pixel(160);
grid.Columns.FromKey("Id").Hidden = true;
//set clientside events Combo box Properties for look
WebCombo1.ClientSideEvents.AfterCloseUp = "WebCombo1_AfterCloseUp";
WebCombo1.ClientSideEvents.BeforeCloseUp = "WebCombo1_BeforeCloseUp";
WebCombo1.ClientSideEvents.BeforeSelectChange = "WebCombo1_BeforeSelectChange";
WebCombo1.DropDownLayout.RowSelectors = RowSelectors.No;
WebCombo1.DropDownLayout.GridLines = UltraGridLines.None;
WebCombo1.DropDownLayout.ColHeadersVisible = ShowMarginInfo.No;
WebCombo1.DropDownLayout.DropdownWidth = Unit.Pixel(200);
WebCombo1.DropDownLayout.FrameStyle.BackColor = System.Drawing.Color.Transparent;
WebCombo1.Width = Unit.Pixel(200);
//if set to false then selected values won't show in combo until you click another spot on the form
WebCombo1.Editable = true;
Then add the following javascript section to handle clientside events:
var cancelClose=false;
function WebCombo1_BeforeSelectChange(webComboId){
//prevents closing of combo while selecting multiple items
return true;
function WebCombo1_BeforeCloseUp(webComboId){
//Cancels premature closing.
if(cancelClose)
cancelClose=
false; return true;
function WebCombo1_AfterCloseUp(webComboId){
//Loop through grid and find all rows that are checked and concatenate the text.
var combo=igcmbo_getComboById(webComboId);
var grid=combo.getGrid();
var rowCount=grid.Rows.length;
var displayText='';
for(i=0;i<rowCount;i++)
var row=grid.Rows.getRow(i);
var checked=row.getCell(1).getValue();
if(checked)
displayText+=row.getCell(2).getValue() +
//display the text in the combo text box
combo.setDisplayValue(displayText);
function GridCellClickHandler(gridName, cellId, button){
//Changes checkbox selection on any cell click in the row
var cell=igtbl_getCellById(cellId);var boolCell=cell.Row.getCell(1);
boolCell.setValue(!boolCell.getValue());
cancelClose=true;
function GridAfterCellUpdateHandler(gridName, cellId, button){
//Prevents dropdown from cloasing after clicking checkbox
cancelClose=true;
That should do it.
Some slight modifications will need to be made for you coumn names/numbers
To retrieve values on client, use a functioin such as:
function getSelectedValues(webComboId)
var displayText='';
var selectedValues=new Array();
var selectedText=new Array();
var aCnt=0;for(i=0;i<rowCount;i++)
var checked=row.getCell(1).getValue();if(checked)
selectedValues[aCnt]=row.getCell(0).getValue();
selectedText[aCnt]=row.getCell(2).getValue();
aCnt++;
alert(
"Selected Values: " + selectedValues.toString());alert("Selected Text: " + selectedText.toString());
To get selected values on the server, the following would do it:
foreach (UltraGridRow row in grid.Rows)
bool isChecked = (bool)row.Cells.FromKey("Checked").Value;
//if checked then do stuff, i simply place items in a listboxif (isChecked)
//listbox is a ListBox server control
listbox.Items.Add(row.Cells.FromKey(
"Id").Value + " - " + row.Cells.FromKey("Text").Value);
I also attached the project to this post.
 Here is what it looks like:
WebCombo Multi
MultiSelectWebCombo.zip
Parents Reply Children
