Does anyone have any idea ho to get at the Headerlayout on the client side.
I have a problem where I have added a second row of custom headers above the normal Grid Column headers. When I hide columns the regular column headers hide auto but the the ones that I added above them do not. The headers I added in some cases span across multiple columns
I created them on the server side like this
ch =
New Infragistics.WebUI.UltraWebGrid.ColumnHeader(True) ch.Caption = "Dates" ch.Style.HorizontalAlign = HorizontalAlign.Center ch.Image.AlternateText = "Dates" ch.RowLayoutColumnInfo.OriginY = 0 ch.RowLayoutColumnInfo.OriginX = 11 ch.RowLayoutColumnInfo.SpanX = 3 e.Layout.Bands(0).HeaderLayout.Add(ch)
On the server side I found I could do a little bit to hide them like this. e.Layout.Bands(0).HeaderLayout.RemoveAt(45) e.Layout.Bands(0).HeaderLayout(45).Style.CustomRules = "display:none"
What I really need to be able to do is get at them on the client and manipulate the SpanX and OriginX properties so I can have them resize properly when I hide the columns.
Hi
I have created a ultrawebgrid with multilevel header server side and it works fine, my problem is iam trying to write client side script to achieve the same.
I donot know how to start as there is no help available.
Please help
Regards
Nitin Mishra
Hi hargreae,
I investigated your scenario under 11.1 and did not encounter any issues when the columns are being hidden. Therefore upgrading your product to the newest release of .NetAdvantage should solve the matter.
To answer your other question, the span and origin of custom headers is accessible and should be configured server side rather than on the client.
Please contact me if you have any questions.
Best Regards,Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
