Hi....I'm an experienced C/C++/C# developer and I'm trying to do some normal, everyday Asp.net stuff...that is probably brain dead simple. But I'm about to pull my hair out.
Can someone answer a couple of questions for me?
I have a UltraWebGrid tied to a AccessDataSource and it's displaying fine. My data is read only and I would like to show some details on the record when the user wants it.
So, I figure that I have two choices and I haven't figured out how to do either.
I couldn't figure out how to get a child band added so I switched to the 'should be simple' child dialog showing details' options, but it wasn't straight forward either.
I THINK my problem is that there is something simple or some keyword that I'm not using to allow me to find what I need.
and how 'bout this asp.net question. Can I use a constructor on a page? How do you launch a page with complex context without being about to construct it?...nevermind... I'm frustrated.
Can someone help me launch a details dialog when someone double clicks on a webgrid row?
thanks,
Gene
Hello Gene,
The sample that I sent you can be used with 2.0 also.
Let me know if you have some questions related to the sample.
Lyuba
Developer Support Engineer
www.infragistics.com/support
Thank you Lyuba,
Perhaps most of my problems is because I'm using .NET 2.0 instead of 3.5 which is what your sample uses.
I'll see if I can punt on 2.0 and move up to 3.5 and get all the goodness. :)
Here is a sample application that shows how you can show a webdialogwindow when it is double clicked on a row of the grid.
Hope this helps.
