In particular, when should I use type instead of another? What are the particularities of each and what do they mean in practical terms? Is one recommended over another?
Hello
You can find the source of the WorldStats showcase at the following link: http://ko.infragistics.com/downloads/DownloadLinkGenerator.aspx?DownloadId=00000000-0000-0000-0000-000000002493
Anatoli Iliev
Hi Iliev,
May be it is not the proper place, but can you help me to find out Sample Code for WorldStats http://labs.infragistics.com/motion-framework/world-stats/ , It looks very impressive and I wish I could see the code to use these features more efficiently.
I have check the following page too but did not find any link: http://ko.infragistics.com/dotnet/netadvantage/silverlight/data-visualization.aspx#Overview
We are going to support and improve the both controls xamWebChart and xamDataChart in the our next release. New features will be released for these controls.
The xamDataChart is providing very good control of the data and the appearence. You can see the following showcases:
Best regards,
Hi Anatoli,
I have indeed read the content from the link you provided. Should I hence assume that gradually the xamWebChart will be deprecated or will it still be actively developed?
Also, I want granular control over the chart component in terms of data and appearance, which one would be better?
Hi David,
The xamDataChart was released after the xamWebChart.control. The xamDataChart control is designed to work very fast with tens of thousands data points. It has a lots of performance optimizations.
You can read more about the xamDataChart at the following link: http://help.infragistics.com/NetAdvantage/DV/2010.3/CLR4.0/?page=Whats_New_xamDataChart.html
